05-15-2010, 20:40 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
05-15-2010, 22:15 | #4 (permalink) |
Insane Poster Join Date: Aug 2007 Location: BOLIVIA
Member: 560732 Status: Offline Thanks Meter: 79 | Unlock e pinout zte S315+ O.K. conector rj_45_ BOX 1 2 box tx ----- 9 (telefono rx) 3 box rx ---- 10 (telefono tx) 4 5 6 7 gnd ------\ 1 8 gnd ------/ conector_2x5_mini --------------- | 1 2 3 4 5 | \6 7 8 910 / 1 --- GND 9 --- RX 10 --- TX test.... COM20 [VCP0] selected module v1.78 Device: ZTE-S315+ Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: ICA-P108A27FM U B01-EnEs-PE01 g5yAV1.0 ES-PE-TELEFONICA-P108A27F Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-static_20100505-155339.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-security_20100505-155339.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-complete_20100505-155341.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_lock-area_20100505-155343.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! |
05-16-2010, 11:22 | #6 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: on earth
Member: 195651 Status: Offline Thanks Meter: 133 | Quote:
not working. may be other phone you tested. | |
05-17-2010, 14:32 | #12 (permalink) |
Member: 195651 Status: Offline Thanks Meter: 133 | don`t spam. we have also other phone with different pcb. look http://forum.gsmhosting.com/vbb/5850362-post8.html |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
