Old 08-18-2009, 08:53   #1 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
Question ZTE X761 Dead After Flash
COM84 [VCP1] selected
module v2.84
Device: ZTE-X761
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA101_En_Es_Pt_Vodafone-Indie.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:6503:000E
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC 292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN_4A6AE6A7].rpl
rom info detection finished
device-id: EFDEC292
rom info protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN
ver. sw 2: X761_Z0_S_A07A105, 581995B5
ffs offset/size: 00D00000/00300000
ffs address assigned: 00D00000
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
firmware patch sp-lock #0/0 applied
firmware patch sp-lock #1 is not required
firmware patch sp-lock #2 is not required
Special operation Done
Write ...
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090818-124056.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090818-124956.B0X.bin
Finished, time used: 563 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to shahzaadbutt For This Useful Post:
Old 08-18-2009, 09:30   #2 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
i flash again with firmware + eeprom now hang on white screen
module  v2.84
Device: ZTE-X761
write: Firmware
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z0_S_A07A105_En_Es.B0M.bin
skip: Customization
write: Eeprom/ffs
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA105__ffs_20090817-142941.B0E.bin
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103.BIN_FDF041C9].rpl
device-id: EFDEC292
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103.BIN
ver. sw 2: X761_Z2_SF_BFFA103, 36BE0F02
ffs offset/size: 00E00000/00200000
ffs address assigned: 00E00000
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103__system_log_EFDEC292_FDF041C9_20090818-131409.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103__system_log_EFDEC292_FDF041C9_20090818-132422.B0X.bin
Finished, time used: 639 sec
Old 08-18-2009, 20:21   #3 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 730
Your original phone firmware was BFFA105 (as per your backup says) so.. flash your phone with 'ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin' this is the more recent firmware in support maybe it can revive your X761, remember select "Format FFS" when flashing.
If your phone doesn't start only solution is to ask Infinity supporters to prepare flash from your backup that is newest.
Hope this can help.
Old 08-18-2009, 20:22   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
1. make "format ffs" in "complete" mode.
2. try to flash phone with other firmware from support area
Old 08-19-2009, 08:37   #5 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
Originally Posted by InfinitySupport View Post
Hello,
i already complete format and flash all firmwares from support area but no success
plz can u tell me i have read its full flash how can i flash with that readed file?
The Following User Says Thank You to shahzaadbutt For This Useful Post:
Old 08-19-2009, 08:46   #6 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Send that flash file to infinity they will convert and upload to support then you can do flash !!
just upload on Rapidshare or any other file hosting server and post link after some time you will able to get file from support and flash it !!
Faisal_Computer
Old 08-19-2009, 08:59   #7 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
here is readed full flash before any operation when phone was locked and 100% ok
http://rapidshare.com/files/26840160...17-142532.html
plz infinity team convert and upload it on support area please
thanx
Old 08-19-2009, 08:59   #8 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
i have flash with this file but phone still dead
COM84 [VCP2] selected
module v2.84
Device: ZTE-X761
"format ffs" active
write: Firmware
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: EFDEC292
firmware patch sp-lock #0/0 is not required
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-124711.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-125613.B0X.bin
Finished, time used: 569 sec
the phone have originally this firmware
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA105
Old 08-19-2009, 10:57   #9 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
successfully revived with my backup readed full flash, thanx to infinity team
module v2.84
Device: ZTE-X761
write: Firmware
ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA105_En_Fr_Es.B0M.bin
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: EFDEC292
Write ...
warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.EFDEC292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 05.BIN_0C16B03A].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.EFDEC292._ZTEMT25_07A _PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA105.BIN_0C16 B03A_.rpl
startup code area #1 backup loaded
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-144145.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-145024.B0X.bin
Finished, time used: 545 sec
Old 08-19-2009, 16:20   #10 (permalink)
Member: 158999
Thanks Meter: 41
Faisal_Computer
friend ilist solution for x761 vodafone dead?
Old 08-19-2009, 16:26   #11 (permalink)
Member: 151871
sorry did not understand !! and if you want to ask any qua , then make a new thread will answer you , and please do not mix the topic
Faisal_Computer
Old 08-19-2009, 16:34   #12 (permalink)
Member: 158999
Thanks Meter: 41
Faisal_Computer
ok your said waths solution for one x761 vodafone dead??
Old 08-19-2009, 17:52   #13 (permalink)
INGSOFT-GSM's Avatar
Member: 1075477
Sonork: 1622970
Thanks Meter: 33
I have 5 phones killed by the bug again q infinity is not a flash in the post FLAS support to repair these phones
Old 08-22-2009, 19:53   #14 (permalink)
celcomputo2007's Avatar
Member: 576154
Thanks Meter: 23
flashing and turned on but now I get signal .... thank collaboration
Old 09-13-2009, 20:33   #15 (permalink)
Member: 807596
I have one that I stay the same after flashing.
that procedure is effective !!!!!!!!
zte 335 dead after flash sneha Various CDMA/TDMA Cell Phones 12 12-25-2010 15:39
Zte x761 dead after repair securite zone ORACHI Infinity-Box 1 01-01-2010 18:08
zte x761 dead :::ANSWERED::: MovilCare PolarBox 3 4 06-16-2009 14:22
Zte 336 dead after flashing loverajgoyal Various CDMA/TDMA Cell Phones 0 04-23-2009 08:50
Zte 125 dead after flash luyanda Infinity-Box 2 01-09-2009 15:31
Page generated in 0.28149 seconds with 9 queries
