01-04-2017, 01:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | Zte z826 Operation : Identify [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26] ID_BLOCK_S : 07CD9A9B ID_BLOCK_I : 008050E1 ID_BLOCK_L : 8DCA1572123214E0BEF226890D7D0814 ID_BLOCK_L : 226B57D962FE283B46A484989025C4A1 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! - report log can't find . This software read phone only in EDL mode . Problem is that phone set up with pressed volume UP/DOWN only , in diagnostic - DFU mode !!! HOW TO PUT PHONE IN EDL MODE ? well, with patched fastboot_edl file, directly with command adb reboot edl , simply as that . problem is, that after read info, must every time restart proceure to be recognized for software. Even then, it wont read firmware, for eqsample, just partial info . ROOT is " done " with k i n go, but after restart gone. with sigma readout , and try unlock looks like : --------- 2017-01-04 01:17:41 --------- SigmaKey 2.21.01 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ ZTE Handset ADB Interface Version: Linux version 3.4.0-g30db9cf-00541-ge52ba85 (wuyanling@zte) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Nov 13 15:21:33 CST 2014 Phone model: zte Z826 Android 4.4.4; Firmware: KTU84P; Date: Thu Nov 13 15:08:37 CST 2014 Version: Z826V1.0.0B05 Baseband Firmware: 0.1.c1.18-00014-M8926DAAAANAZM-1 Baseband Processor: Qualcomm MSM8926 Date: Nov 13 2014 17:07:48, Oct 08 2014 02:00:00, DAAAANAZ Software IMEI: 864918028524948 Security area saved to "C:\+++++++++\SigmaKey\security backup\864918028++++++_zte_Z826_KTU84P Restarting phone...Done but seems to meshup data, now phone don't accept even original SIM.Newer mind... how can I help to add this phone to be suported? Last edited by Crumarix1; 01-04-2017 at 01:41. |
01-06-2017, 11:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. This device, as can see from logs, connect in EDL mode well. But this secure type not supported yet ( not sure about it will be supported at all, but we will try ) |
