Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TST Dongle
TST Dongle Total Samsung Tool
Old 02-28-2006, 10:08   #1 (permalink)
Member: 127030
Dongle problem
Hello,
I have a new dongle but can't use it so far. When I install drivers on XP and run TST_Detect.exe it says:
Your TST Dongle ID is: 7B0xxxxx
This is Dongle #3
Now if I run "_Total_Samsung_Tools_v2.99_BETA.exe" from the Dongle3 folder it says "You need to installe Dongle driver and plug in TST dongle for install". But it's plugged in and when I run the soft it's even blinking.
So no success with 2.99. When I run TST V3 Internal_5.exe it's working fine, just sysol is disabled. I guess that's how it should be in 3.0.
So how can I run 2.99??
Old 02-28-2006, 10:47   #2 (permalink)
Member: 127030
Thanks for online support guys. I'll try the suggestions that TST team is giving me and will update it here.
Old 03-01-2006, 09:45   #3 (permalink)
Member: 127030
I think no one cares about support here.
Old 03-01-2006, 10:33   #4 (permalink)
Member: 125695
Thanks Meter: 3
sorry for lat reply . check ur pm i send u instructions .
check this way and send me pm if still problem.
T/T
Old 03-01-2006, 11:00   #5 (permalink)
Member: 127030
I followed instructions, no joy.
Check PM.
Old 03-02-2006, 22:46   #6 (permalink)
Member: 127030
Hello? Knock knock... anyone here?
Old 03-04-2006, 07:55   #7 (permalink)
Member: 125695
Thanks Meter: 3
after checking ur details regading this problem .i think you must replace dongle .we just spoke with ur resaler . just send him back dongle and he will send u tested dongle .
T/T
Old 03-08-2006, 12:08   #8 (permalink)
Member: 25930
Thanks Meter: 4
Hi TST team,
i have today problem with dongle too, but befor work very good.
Please send me instruktion
Thanks
hrich
Old 03-11-2006, 15:23   #9 (permalink)
Member: 243168
Dongle Problem
I have had my tst for some time now but now it show please install dongle drivers. It showing rocky in system but i tried uninstall/reinstall/reboot and every combination without any luck.
Shamas
Old 03-13-2006, 21:31   #10 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
I thinkl some of you have problem whit usbsmart Motorola also i have problem after install usbsmart i can't run Tst but all is ok dirver reinstalled and faitian rockey4 is found by Pc well but when start program no key found.
Old 03-13-2006, 21:36   #11 (permalink)
Member: 127030
1. I've tried also on PC that doesn't have usbsmart ever installed on it
2. In my case the problem only appears when I run 2.99 Setup! My reseller sent me the whole directory of installed tst and all programs worked. I'm also able to run the software that is not packed into setup like swift or 3.0...
So I'm more that sure that the problem is in SETUP and not dongle.
Anyway, I'm waiting for new usb dongle just to try... Thanks to my reseller.
Old 03-14-2006, 01:30   #12 (permalink)
cairnquay's Avatar
Member: 64893
Thanks Meter: 221
Shamas
Mr Shamas, You sent your PC to us.
1. Your program kept asking to install driver/dongle.
2. I checked and found your problem even though sn reader finds dongle and showing ok in start/control panel/system/hardware/device drivers.
3. I deleted your desktop shortcut.
4. Opened c/program files/tst and clicked on the tst_menu icon.
5. Your program works fine from this shorcut.
Everyone else with same problem should try doing same as above.
Post results here. This bug maybe be fixed next update.
Brightmobile.com
Old 03-14-2006, 13:13   #13 (permalink)
Member: 127030
So this is not similar to my problem, right?
I can't even install it.
Brightmobile.com
Old 03-14-2006, 13:25   #14 (permalink)
Member: 25930
Thanks Meter: 4
I have same problem with dongle after instal usbsmart dongle driver...
i uninstal usbsmart and then reinstal driver for TST and now all work ok.
hrich
Old 03-14-2006, 17:45   #15 (permalink)
Member: 3381
Thanks Meter: 1,171
The best system is to delete driver of TST install usbsmart motorola and after in another usb port install tst again and all work now.
Twister Dongle / USB Smart dongle problems Icumobile Twisterflasher 0 03-01-2006 09:09
zulea dongle .........probleme ??? GSMpedro BF, BG, TH, BHx Series 0 07-04-2003 19:56
TERMINATOR DONGLE PROBLEMS,,,any help.....? GSM Solutions Ireland Sony Ericsson 3 06-05-2003 15:48
maxim dongle problem asas x1x to x45/x50 16 10-27-2002 22:48
Nokia dongle problem... omelette Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-05-2000 17:58
Page generated in 0.21046 seconds with 9 queries
