11-24-2011, 05:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | @@..Remove Nokia all bb5 security code with all box that support usb trick--mobi_soft @@..Remove Nokia all bb5 security code with all box that support usb trick by mobi_soft..@@ To Factory reset, or reset user data quick and easy, no need to flash: Connect the phone using any universal f-bus cable Use b+, bsi, gnd from universal f-bus instead of using battery or external power supply Next connect phone directly to PC USB... then power on the phone Phone will show 'testmode' on screen Drivers will install ok Use Mt-box, Mx-key, Cyclone, etc, etc to make reset in USB mode Dont forget to say thanks if this info was useful to you. mobi_soft |
The Following 10 Users Say Thank You to mobi_soft For This Useful Post: |
11-24-2011, 06:25 | #2 (permalink) | |
Insane Poster Join Date: May 2009 Location: Comilla Bangladesh Age: 36
Member: 1029677 Status: Offline Thanks Meter: 55 | Quote:
This Is Right Solution BR. | |
The Following 3 Users Say Thank You to mobarak For This Useful Post: |
11-24-2011, 10:02 | #4 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | wow. Discovery of the year, alll waiting for this HOT solution. You are big man and thanks button should goes to you! heh |
The Following User Says Thank You to online-nokia For This Useful Post: |
11-24-2011, 12:44 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | nothing new man here is very old and easy way: just use 4.7 k resistor between bsi and - (negtive) press on/button set will goes to local mode do what you want.... |
12-04-2011, 19:55 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Somewhere in Spacetime Age: 48
Member: 168364 Status: Offline Thanks Meter: 174 | Thanks! I knew this a long time before. Don't try this with fbus & mbus connected! Phone won't be recognised! Only battery connectors! W B R |
