03-08-2010, 03:04 | #1 (permalink) | ||
Freak Poster Join Date: Sep 2007 Location: On Muhammad's Way
Member: 597789 Status: Offline Thanks Meter: 147 | 5130 Contact service solutions (security and simlock) 5130c RM 495, is Nokia BB5 of SL3 category... therefore, many people say that this type is not supported for unlock and simlock repair as well as contact service reparation. Is it true........??? Hmm.....before elaborating the facts, there is an important question: what is SL3 or Security Level 3? We better understand from the beginning......SL1, SL2, SL3.......... There is a lot of informations in many forums but each explains differently. However, based on my concern and belief, those are classified as the followings: SL1(Security Level 1) = Nokia BB5 first generation which doesn’t have PM 120 area SL2(Security Level 2) = Nokia BB5 with PM120 area and the area contains simlock data connected to PM308 value SL3(Security Level 3) = Nokia BB5 with PM 120 area and PM308 area is protected I’m very welcoming for any correction......... Based on the above classification, the next question is “what can be and cannot be done on that each type??? Quote:
5130c(RM 495) = Nokia BB5 SL3, Is it possible to fix contact service case on this handphone???? First, we better understand on how contact service case emerge.... Contact Service “This faults means that the phone Software is able to run and thus watchdog of CPU can be served. Selftest Functions run when power is switch on and software is executed from combo memory. If any selftest fail, a “Contact Service” text is shown on LCD.” The point is, when handphone switched on, then cpu will perform several test (selftest). If one of selftest fail, then “contact service” will show on LCD. Generally, failure is caused by selftest failure on security test and simlock test........ Security Test is related to PM 1 and PM 309 value, if one of or both value within the area is not valid, then selftest result on security test will be failed. Then comes “contact service”. Solution : re-write area PM 1 dan PM 309 using valid valuei Simlock test is related to PM 120 and PM 308 value, when one of or both value within the area is not valid, then selftest result on simlock test will be failed. Then comes “contact service”. Solution : 1. If the problem is on PM 120 value, you can try to re-write that area using valid backup (if you have). But if you don’t have, just make your own PM 120 section 0 using some existing tools free, then ty to re-write the area... 2. If the problem is on PM 308, seems that no tool is able to fix it recently because PM 308 is protected, can’t be re-written (some says it could be by using some tricks). What I believe is, PM 308 area has little possibility to corrupt because the area is protected, so if you have contact service problem caused by simlock test failed, it maybe mostly because of corrupted PM 120, not PM 308. Exampleof log caused by corrupted PM 120... Quote:
“5130c is Nokia SL3, not support unlock, wait for update...” this is true, but this sentence often put on a wrong place so i think rather misleading. The above log is not because handphone locked, but because one of simlock data (PM 120 area) corrupt. So, just fix it, no need unlock. Unlock Provider is a process of opening provider key installed to nokia handphone that is locked on certain provider. Because one of simlock data is located on PM 308 area, so unlock cannot be executed for this moment, PM 308 is protected from re-write operation process through flash mode. Thanks for OM togel Mania, Om Andra, Om G-blues, else.... | ||
The Following 28 Users Say Thank You to Biocell For This Useful Post: |
03-30-2010, 11:36 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Hello Age: 38
Member: 99115 Status: Offline Thanks Meter: 99 | Does any one repaire that condition 5130 with pm 120 repair ?? SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
The Following 2 Users Say Thank You to sushilsoni2003 For This Useful Post: |
03-30-2010, 11:53 | #3 (permalink) |
Member: 597789 Status: Offline Thanks Meter: 147 | i dont know...i dont have mxkey on that day.... but i have done repair contact service because simlock.... using pm120 repair... cek this thread.... http://forum.gsmhosting.com/vbb/f299...ervice-910348/ |
The Following 2 Users Say Thank You to Biocell For This Useful Post: |
07-05-2010, 15:26 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Nokia 5130 contact service solution http://forum.gsmhosting.com/vbb/f148...n-here-820743/ |
The Following 4 Users Say Thank You to rafi_5217705 For This Useful Post: |
02-03-2011, 12:57 | #6 (permalink) |
Freak Poster Join Date: Oct 2010 Location: NARAYANGANJ BANGLADESH
Member: 1420901 Status: Online Thanks Meter: 20 | SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! I need help pls help me. |
The Following User Says Thank You to NUR ISLAM For This Useful Post: |
02-03-2011, 16:57 | #9 (permalink) |
No Life Poster Join Date: May 2004 Location: GaZiPuR,BaNgLaDeSh Age: 38
Member: 66430 Status: Offline Sonork: 100.1601372(iN YoUr mInD) Thanks Meter: 1,987 | yet no have solution for 5130 contact service |
The Following User Says Thank You to GOLDEN-SHARIF For This Useful Post: |
03-03-2011, 14:21 | #11 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: DHAKA BANGLADESH Age: 37
Member: 1441250 Status: Offline Sonork: 100:1602230 Thanks Meter: 199 | Quote:
100% solution 80 credit with mt box | |
The Following User Says Thank You to Sarder For This Useful Post: |
03-23-2011, 21:37 | #14 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: india
Member: 687718 Status: Offline Sonork: 100.1603913 Thanks Meter: 121 | may i ask Quote:
PLZ POST FULL PROCEDURE WITH IMAGE IF POSSIBLE THANKS IN ADVANCE | |
The Following User Says Thank You to manishavar15 For This Useful Post: |
05-03-2011, 11:57 | #15 (permalink) |
Junior Member Join Date: Sep 2007
Member: 583410 Status: Offline Thanks Meter: 7 | SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! plzz help me about this 5130 |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
any nokia 5130 contact service solution | sushilsoni2003 | Nokia Base Band 5 ( BB-5 ) | 4 | 04-05-2010 02:37 |
the diffrent 5130 contact service by security or simlock | ekel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-23-2010 16:49 |
5130 contact service solution ? | asifdogar | Universalbox | 1 | 12-27-2009 17:40 |
How to fix a 5130 contact service (no simlock and no superdongle) | shaazad | Trash | 2 | 12-26-2009 11:33 |
