Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Nowhere
Member: 739774 Status: Offline Thanks Meter: 89 | 5200 version 5.53 can't unlock, Downgraded to 5.51 but phone can not unlock! I have a problem with unlocking 5200, version 5.53 is not support for unlock. I downgraded to 5.51 but not helped! I have no problem with cables! Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_359816014445122_Locked_Keycnt_0_Fbuscnt_0__V_0 5.51_05-09-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. Mayby something is wrong, can anybody help me plz? Thanx |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Keep trying, change gnd location, try also without gnd, try to set delay to 1 sec, also try enable/disable "test connection with phone", finally it will work... Or borrow another cable, like i did once, after 15-20 unsuccessfull attempts, though my cable was ok with other phones. BR |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2006
Member: 268154 Status: Offline Thanks Meter: 40 | here is your problem: Cable wrong codes counter: 10 wrong tries from max. 10 tries u have 2 options: 1 if you recived the phone before the counter has no more attemps u can restore it with the back up file, 2 u have tu buy a rpl file. |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | Quote:
![]() tested 100% by me on Nokia 5200 br | |
hellow ub team i unlock 6220c credit is lose but phone is not unlock return credit | AYAZ42 | Universalbox | 0 | 03-27-2009 16:24 |
I flashed two times with two different unlock patch files.But phone is not unlocked. | caremobiles | Z3X-Team Products | 5 | 02-09-2009 20:55 |
Was able to read information from my M600i, but can not unlock it. | Glitterfang | KULANKENDI Server | 2 | 07-12-2007 01:51 |
