11-08-2009, 13:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | I m very said no master no genius here SL DATA Cruppted I have UFS And Jaff Box But Problem Not Solve. All Tricks And Solutions Are Bad So I Desaide Leve This Mobile Repairing Work Becoz No Body can Help me I M Very Thankful for All Becoz This Forum learn me A lot but its end By for all Masters And Student |
11-08-2009, 13:06 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
11-08-2009, 13:47 | #6 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Br.. Tell Ur model and post Ur full log.....?? Mean while Just unlock Ur set using UB and post the result.... Hope will be ok |
The Following 2 Users Say Thank You to sky_finder For This Useful Post: |
11-08-2009, 13:58 | #8 (permalink) | |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | Quote:
for your problem to fix the corupted sl data in 5130c only rpl than write with mx key dongle not else because like you say you already try all trick in this forum , now you can try the last ways ( RPL than write only using mx key dongle couse just only mx key dongle can write rpl for 5130 with corect way accept original nokia flasher with tucson server ) but for now rpl bb5 still down so be patient my friend ! | |
11-08-2009, 13:59 | #9 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
11-08-2009, 14:02 | #10 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Here is the log MCU SW : V 06.94 21-07-09 RM-495 (c) Nokia PPM SW : V 06.94 21-07-09 RM-495 (c) Nokia SSA Prd.Code: 0577793 Bpr.Code: 0567772 Prod.Sn : IIN757806 HW Vers : 2000 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 06540601 DSP Vers: ICPR72_09w04 LCD Type: SEIKO IMEI : 354223-03-161209-6 SL Serv : SIMLOCK SERVER SL Conf : 000-00-00000000000 SL Prof : 0145191B00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found |
11-08-2009, 14:08 | #12 (permalink) | |
like i says that the only ways to solve your problem issssssssssss RPL AND MX KEY FOR NOW trust me ! | |
The Following User Says Thank You to juwanapati For This Useful Post: |
11-08-2009, 14:18 | #13 (permalink) | |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
http://www.mediafire.com/?n2guyzyljyy | |
11-08-2009, 14:25 | #14 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | Quote:
If you cannot help your self then find another job maybe that job will fit you.... goodluck to your new path | |
N95 8GB NO lights No Display soulution here | GSM Deals | Nokia Hardware & Hardware Repair | 39 | 10-05-2010 19:40 |
u600 keys very strange problem.. plz hlp me here.. | peter002 | HWK | 6 | 06-15-2009 15:39 |
z400 and ZXXX master code rest here please | karouk | UST Pro II | 6 | 08-14-2006 19:06 |
