5300 strange problem hi everybody i have a 5300 that seems to be dead not powering neither charging but sometimes after several attempts to switch it on, it turns on up to nokia logo then turn off and sometimes it powers on normally and works perfectly and after u turn it off it is dead again. i tryed to flash it with jaf usb dead but i got error init usb flashing. i didnt try with fbus i dont have the cable can someone tell me if it is sotware problem or hardware and if so in what part is the problem ? thanx to all helpers |
I Think Its Hardware Problem................ |
trhgis is a hardware problem check supply on battery connecter |
hot your tanvo and CPU |
check theboard maybee board fall down & check all ic which ic bistarbd thats solved |
;););)Hardware Problem................ |
that is hardware bro... try to reheat flash ic... I already did one like that... |
yes, bro..it needs to be hardware repair..like flash ic its maybe lost contact.. |
it's a hardware problem, you have to check the IC's and when it turn on try to touch the board you will find one IC that will be burning you can fell it's temperature, 90% the power IC, try to clean it, reheate and/or change ;) |
thank you for all helpers i hheated all ic's but in vain i tryed to twist the board to see it it could turn on but nothing now it's complitly dead i cant power it at all!! i tryed to check it with jaf fbus this is the result : CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1450000C98F1505642E7F5A32D98B3B125C0A1E6 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: D:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22FE00EC <=> SAMSUNG (SEC) -> K8S5615ETA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: D:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg Loader version: 01.0C.05 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready when i tryed to flash it it gave me error after areasing...., i think its flash ic, i heated it but always same result, any other suggestions? |
