Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-30-2008, 14:43   #1 (permalink)
sukhdeep's Avatar
Member: 348478
Thanks Meter: 62
5300b unlocking problem with bb5-box
5300b unlocking problem with bb5-box unlocking fail pl help log is here
------ Operation: UNLOCK V1 Date: 29-04-2008 Time: 06:39:44 -------
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-146
Version: V_04.71_28-02-07_RM-146_(c)_Nokia.
IMEI: 35273201*******
SP LOCK status:
Config Key: 3027200000000000
Block 1: CLOSED Type 5 Data: 302720
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-146_35273201******_Locked_Keycnt_3_Fbuscnt_10__V_0 4.71_28-02-07_RM-146_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest counters ...
Finded backup file: RM-146_352732014******_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-146_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 08
Try number (Cable): 2
Response byte: 08
Try number (Cable): 3
Response byte: 08
Try number (Cable): 4
Response byte: 08
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Unlock fail. Please try again.
Old 04-30-2008, 16:14   #2 (permalink)
Member: 481700
Thanks Meter: 14
Change ground place ... try it in the vibror
Old 05-01-2008, 15:09   #3 (permalink)
Member: 511668
Sonork: 100.1604959
Thanks Meter: 8
5300b flash help ufs or jaf
Old 05-01-2008, 15:15   #4 (permalink)
Member: 367723
Thanks Meter: 346
dear members where is bb5 box support forum.pease give me reply.
Old 05-01-2008, 16:14   #5 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,086
http://forum.gsmhosting.com/vbb/showthread.php?t=532603
problem unlock 3250 with BB5-BOX iran-mobile-team BB5BOX 3 04-08-2008 11:51
strange problem with bb5 box ikrash BB5BOX 1 03-22-2008 17:02
Problem With Bb5 Box AbdulKadir BB5BOX 12 03-19-2008 15:13
n95 unlokig problem with bb5 box geepee777 BB5BOX 13 02-04-2008 20:39
5300b ver 4.51 unlocked susecfull with BB5 Box.....100000% Bao Tran BB5BOX 0 10-15-2007 08:10
Page generated in 0.15806 seconds with 9 queries
