about nokia bb5 sl3 i have read this solution from forum it is true and any one tested this solution :confused::confused::confused: SL3 /SL2 FREE Solution for Nokia Software Demaged Phones -------------------------------------------------------------------------------- SL3 /SL2 FREE Solution for Nokia Software Demaged Phones ----------------------------------------------- This Is tested by us for SL3 & SL2 Phones & it Works 100 %. if phone shows any of the followings after Unlock attempt .contat servicre .phone startup failed .failed to read .RPL SL3 PHONES NOT SUPPORTED Do NOt worry because you do not need RPl or SX4 and would n't cost you anything You need to have Mt Box and follw these steps 1)Connect the Phone to MT Box 2)Select PM Edit option 3)Type 120 in 1st field and 0 in 2nd field 4)You will see some information in window Simply Select All and delete it 5)You should be having Same network Locked Phones's data 6)Simply copy and paste the information in window 7)Press Write Its All Done :-) ;-) In some SL2 Phones you need to Unlock again it will be ok ================================= I will upload some Locked data files & will request all Forum Users to upload the Locked 120 Fields so that others can get benifits if they do not have same Phones kan any one send me a reded pm for 5220 orange france i will test and post rsult ;) |
kkkkkkkkkkkk false solution |
