02-26-2010, 09:16 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: facebook.com/sMARTyRuLezZzz Age: 34
Member: 1080440 Status: Offline Thanks Meter: 606 | <<BB5 Easy Tool by DSSv03 new update>> BB5 EasyTool v0.3 aka DSS Supported interface: USB, COMport, UFS How to Read an ASK files from BB5 phones: - Switch ON the phone - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - Click 'Read ASK' How to Write RPL files to BB5 phones: - Switch ON the phone - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - Click 'Write RPL' - Note: This function will write only SIMLOCK DATA to the phone, for imei repair you need flashers! How to use DSS as easyUID: - Copy DSS.exe to UID directory - Make proper testpoint to the phones - Switch ON the phone(with CORRECT testpoint connected between phone and UID BOX) - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - For better result, you should set then phone mode to 'TEST MODE' before unlock process - You will see 'easyUID' page. - Click 'Hook' - Select Phone model listed on bb5_unlock.exe(UID SW) - Click 'Init' on bb5_unlock.exe - Set 'options' to use #pw+...+?# if required. - Click 'SP unlock' ('delay' before unlock process implemented) - Wait for bb5_unlock.exe to work, DSS.exe will automaticaly detect the code calculated by bb5_unlock.exe and write it to the phone. Download link is here: http://www.gsmsimlocking.com/BB5/ind...asy_UID_by_DSS |
The Following 3 Users Say Thank You to blast.gsmhost For This Useful Post: |
BB5 Easy Tool by DSSv03 new update !! | Electroboys | UID - Box | 63 | 12-04-2011 19:36 |
New Service : Easy-Tool logs | AMINOS | GsmFreeShop-SERVER | 5 | 02-24-2009 07:30 |
How can I unlock v66 by Easy tool? | Argo_Andrew | Motorola P2K (USB-Smart) | 3 | 07-08-2006 12:18 |
c975 dead by crack easy tool 3.9 | sepid | Motorola P2k | 4 | 06-12-2006 23:16 |
