Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-11-2006, 23:14   #1 (permalink)
Member: 312740
cannot reflash dead nokia6280 help
cannot flash dead nokia 6280 error msg:trying to verify communication filed,cold not verify communikation to UA.0x8401225A(-2080300454)adl loader does not start.this may hapen if USB has not jet configuret,in this case wait USB to configure and restart the operation.In X products this can mean than wrong dcm dll is used.Help me plz!
Old 10-12-2006, 01:05   #2 (permalink)
NBG
NBG's Avatar
Member: 3101
Thanks Meter: 6
You just have to be patient and it will work after many retries,use latest 156 phoenix and latest 5.92 firmware,dead phone usb flash work with this versions.
Old 10-12-2006, 08:17   #3 (permalink)
Member: 234577
had the same problems. if flashing is over and phoenix wants to verify the proces and the message you describe appears, disconnect the phone and connect it after that push retry button and all will be fine!
Old 10-12-2006, 16:04   #4 (permalink)
Member: 41760
Thanks Meter: 16
First, in Phoenix, under Manage Connections, select NO CONNECTION (or move it to the top of the list if you have several options there already). Press APPLY then CLOSE.
Second, under File menu, select Open product and choose your model. Then select Flashing - Firmware update, choose product version and Phone as Manufactured/refurbish. Checkbox USF flash dead phone will be activated, check it, then press Flash button. When requested, press the power button on the phone. Should work. Worked like miracle for me (6270, 6280 & 3250).
Old 10-12-2006, 18:20   #5 (permalink)
Member: 312740
Thanks,but i cannot download 5.92 firmware from rapidshare
Old 10-12-2006, 23:12   #6 (permalink)
Member: 312740
i get 5.92 firmw,but nokia 6280 still dead
Old 10-13-2006, 07:23   #7 (permalink)
Member: 339311
I tried flash as dead phone(6280) with firmware 3.70,3.81,3.82,5.92 and software phoenix (versions: 2006_20_9_148, 2006_20_14_153, patch_2006_20_15_154, 2006_34_2_156), many times(more month), but phone still dead.
i think not valid crack to phoenix 2006
p.s.
Sorry for my english
Old 10-13-2006, 08:04   #8 (permalink)
Member: 41760
Thanks Meter: 16
oops123, maybe the problem is not in the software? Was the phone working before you flashed it? Did you notice what version of firmware it was on? Because I have personally flashed successfully 6280 from dead state (turns on, shows Nokia and dies) using NO CONNECTION method in Phoenix. The procedure is described a couple posts above. If this fails, maybe the problem is in thephone hardware... Or if you downgraded the phone firmware, which is bad.
Old 10-13-2006, 09:33   #9 (permalink)
Member: 339311
When phone worked firmware was 3.70.
in process reflashing to firmware 3.81 got error message(about 80%-90%), phone dead.
i use NO CONNECTION but still dead.
p.s.
sorry for my english
Old 10-13-2006, 10:04   #10 (permalink)
Member: 41760
Thanks Meter: 16
Originally Posted by oops123 View Post
...in process reflashing to firmware 3.81 got error message(about 80%-90%), phone dead.
Empty battery? Try charging it with another phone, or put a battery from another phone in and try again.
Also, if battery is not a problem, try a different set of firmware files. Maybe yours are corrupted. The best way would be to download and install the full data package. Search for my other posts, I have posted links to 5.92 data package. That's a full working one. Tested.
Old 10-13-2006, 10:24   #11 (permalink)
Member: 34594
Thanks Meter: 26
Flash the phone using DEAD USB FLASHING with a Jaf box , a DKU cable , 6280 sw version 5.92 . and all will be ok.
This is the thread- http://forum.gsmhosting.com/vbb/show...ight=6280+DEAD
Ayoade
Old 10-13-2006, 10:34   #12 (permalink)
Member: 339311
i have firmwares.
buttery was full.
its now buttery empty(control with multimeter 2.81 volts), but i may charging.
i tried also some versions driver
p.s.
Problem Reflash Roger TU515 !!! help,help,help breyton VygisToolbox 12 04-17-2009 01:22
Please support and others,I cant reflash Nokia 6290 HELP alexvideogames Universalbox 1 01-26-2009 13:40
Cannot Reflash Nokia 7390 With New Product Code. Please Help!! dtakias2 Nokia Base Band 5 ( BB-5 ) 4 02-15-2008 00:53
Dead C650 After reflash I Need Help ! leviatan21 Motorola P2k 1 02-18-2005 18:21
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16876 seconds with 9 queries
