Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-05-2011, 21:41   #1 (permalink)
Member: 590644
Thanks Meter: 146
[Download] Nokia Care Suite 4 Store 2011.18.3 (Free Original Nokia USB Flasher)Tested
Download: Nokia Care Suite for Store 2011.18.3 (Virus Free)
Tested and Working
Pass: genuine
Description:
Care Suite (CS) is a Multi-protocol software who support latest nokia CDMA,GSM and WCDMA (328 models covered)
It's a Free software (OpenSSL), relased by Nokia Care for stores.
ARE YOU LOOKING FOR THE BEST USB FLASHER ON THE MARKET?
YOU DON'T NEED TO PAY FOR THE BEST NOKIA FLASHER, BECAUSE THIS IS THE ORIGINAL AND IT'S FREE!!!!
What the software can do?
- User Friendly GUI
- DEAD USB Recovery
- ADVANCED Self-Test
- Backup User Data
- ORIGINAL NOKIA USB FLASHER (328 models covered)
- Supports MULTI-FLASH (2/3/4/8 phones flashed in the same time)
- Download the correct firmware from the Nokia Care Servers (Fast and Secure)
- Refurbish/Software Upgrade (without loosing data)/Soft Reset
- Work under Win XP/Vista/Seven x86
- May Support protocols F/M-Bus by using FPS-10/FPS-21 Interfaces
Happy Refurbish!
Freeck!
The Following 10 Users Say Thank You to Freeck For This Useful Post:
Old 06-06-2011, 13:22   #2 (permalink)
Member: 219795
is there anny big difference between this and phoenix?
Old 06-06-2011, 22:22   #3 (permalink)
Member: 590644
Thanks Meter: 146
Phoenix is more complete, but if you don't have the original nokia hw can't use advaced functions....
Nokia Care Suite, have the same routines, but more quick and intuitive if you need only a simple flasher
Old 06-07-2011, 10:24   #4 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Dose it support dead usb flashing like phoenix?
Old 06-08-2011, 08:51   #5 (permalink)
thechachman's Avatar
Member: 595947
Thanks Meter: 16
Getting following error on clean install on WinXP:
Product: Nokia Care Suite 4.0 -- Error 1904.Module C:\Program Files\Common Files\Nokia\Service Layer\C\Service Modules\ServiceModule_00003\msxml4.dll failed to register. HRESULT -2147023782. Contact your support personnel.
Old 06-12-2011, 17:47   #6 (permalink)
Member: 1589457
Thanks Meter: 9
Of course, you have to open Tools/Phone Recovery, select your model, the USB port and start recovery
Best Regards
Old 06-13-2011, 18:31   #7 (permalink)
Member: 590644
Thanks Meter: 146
Register the File Manually
To register a specific file again in the registry, while you are working in Microsoft Windows, follow these steps:
a) Click Start and then type cmd in the start search bar.
b) Right click on the result and select Run as Administrator.
c) In the Open window, type the following command, and then hit Enter.
RegSvr32 <filename>
Where <filename> is the name of the file specified in Error 1904 (msxml4.dll in your case)
Let me know...
Best Regards
The Following User Says Thank You to Freeck For This Useful Post:
Old 07-03-2011, 21:31   #8 (permalink)
Member: 41063
Thanks Meter: 9
thanks freeck for the soft
when you try to recover a dead phone wich usb port do you select?
Old 07-04-2011, 16:42   #9 (permalink)
Member: 590644
Thanks Meter: 146
Hi, depend of connected devices in your pc.
If the phone it's the only device plugged on USB you can select the first port avaiable on selection
Let me know if works well or have troubles recognising the dead phone.
Freeck!
Old 07-04-2011, 19:15   #10 (permalink)
KKBaruah's Avatar
Member: 1540165
Sonork: 100.1606502
Thanks Meter: 29
Freeck!
Br, when I install nokai care suite shows roll back action after few second of installation. Why?
Old 07-04-2011, 22:04   #11 (permalink)
Member: 590644
Thanks Meter: 146
Have you installed any nokia software in the past?
Try to clean UP your system bro
Freeck!
Old 07-04-2011, 22:56   #12 (permalink)
Member: 41063
Thanks Meter: 9
i formated the pc, installed xp and then the program
it's a dead phone... phoenix flash the phone well with the option "no connection"
your program keeps telling me to turn phone on when you get 50% of the process (when finishes the download of the firmware and begin the flash)
phone is in usb 1 (autodetected by the program)
Old 07-05-2011, 13:46   #13 (permalink)
sakisager's Avatar
Member: 149804
Thanks Meter: 96
Exclamation upload it on hot file filesonic
can you please upload it on filesonic or hotfile server ??
Tested and Working
Pass: genuine
Description:
- User Friendly GUI
- DEAD USB Recovery
- Backup User Data
Happy Refurbish!
Freeck!
The Following User Says Thank You to sakisager For This Useful Post:
Old 07-15-2011, 22:52   #14 (permalink)
Member: 590644
Thanks Meter: 146
http://forum.gsmhosting.com/vbb/f299...ested-1305566/
Try here, the first link it's the updated version of Nokia Care Suite downloadable from filesonic
Regards
Old 10-14-2011, 02:21   #15 (permalink)
Member: 1223565
the file is password protected, cant unrar
Page generated in 0.27141 seconds with 10 queries
