![]() | #196 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2007 Location: Malaysia Age: 40
Member: 568101 Status: Offline Thanks Meter: 18 | Quote:
![]() | #198 (permalink) | |
...this non B backup....rm-235 Last edited by fendy2007; 01-22-2009 at 13:59. | |
![]() | #199 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Unknown Age: 40
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | ok attached file test it with jaf plan rpl and write to phone always backup crt before making test. if successes post results. i add this file to both free link to download for all other members. you can compare both file original and made by me to see what i have made. all already in first post. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
![]() | #200 (permalink) |
Member: 568101 Status: Offline Thanks Meter: 18 | actualy i have n78b .....thats phone not support 3g...and i try to write bandlockcode.rpl...but not done yet....what can i do to settle this prob? |
![]() | #201 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | Quote:
about 3g i have not done much r&d on that part because no 3g in my place. but you can try to write pm fields 1 and 309 before u write you have to backup original in case any problem come. do sx4 write working fields and test phone. i think firmware making this problem so did u try to flash with n78 firmware with downgrade trick? but as i say i have no idea for 3g yet. | |
![]() | #202 (permalink) | |
yes done.thanks..i will try all software,,, but same..now i try to write pm..hope is done... | |
![]() | #206 (permalink) |
Junior Member ![]() ![]() Join Date: Apr 2008
Member: 755612 Status: Offline Sonork: me_fmb Thanks Meter: 4 | P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 006.044.048 Elf2flash 07.19.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ....................Loader Sent! Stage 2 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Phone failed to boot in flash mode CMT... this is the problem in my N 81 8gb plz help me someone |
![]() | #207 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2008
Member: 926425 Status: Offline Thanks Meter: 33 | hi i have nokia n71 after flshing with latest version firm ware give me the message phone strt-up failed contact ur retailer plz any one have a solution to help me khalid khan qisa khwani |
![]() | #208 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jul 2005 Location: Germany Age: 47
Member: 159805 Status: Offline Thanks Meter: 1 | hello stanner_austin, my friend just came to me with bricked N95 8Gb (RM-320) - just white screen, he did downgrade via usb and its failed. I took the phone and make a rpl backup immediately with jaf. He gave me pm308 backup which he made before. I did: - erase phone with BB5Erase_UNI_rapido.bin - flash new with newest FW - write pm n95-8gb modifyedRM-320.pm (just field [1] and [309] so i do not need SX4 auth) - write full pm (rest field) - write backup rpl which i made before now phone is in contact retailer, my question is: - Could it be that the rpl backup which i made before, is damaged already because of usb downgrade? log before i write rpl backup IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 11 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN i got this log when i write rpl backup back NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA NOT FOUND... HWC DATA NOT FOUND... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA NOT FOUND... SIMLOCK KEY DATA NOT FOUND... SUPERDONGLE KEY DATA NOT FOUND... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... now is like this IMEI plain: 354829020477240 IMEI spare to net: 3A 45 28 09 02 74 27 04 IMEI SV to net: 33 45 28 09 02 74 27 14 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN i follow all your guide here http://forum.gsmhosting.com/vbb/show...91&postcount=4 and your 1st post, but the result still the same. Could u help me pls, should i buy rpl ? Thx very much in advance |
![]() | #209 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | @punktde you are still forgetting main few step. imei should be ok sp are should be ok if both ok you just have to do SX4 correctly. if sx4 ok just write pm modified one. check now phone if same post what self test is failed and post here. |
![]() | #210 (permalink) |
Member: 159805 Status: Offline Thanks Meter: 1 | @stanner_austin thx for your reply, but what about my question "Could it be that the rpl backup which i made before, is damaged already because of usb downgrade?" and is this log ok? NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA NOT FOUND... HWC DATA NOT FOUND... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA NOT FOUND... SIMLOCK KEY DATA NOT FOUND... SUPERDONGLE KEY DATA NOT FOUND... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... |
Samsung T509 lock for all providers | mapalma | Samsung Flashers, Software, Firmware. | 6 | 01-02-2009 12:44 |
New last flowchart for repair bb5 contact retailer | morteza-icu | Nokia Base Band 5 ( BB-5 ) | 0 | 09-26-2008 17:33 |
How to know BB5 Contact Retailer from RPL or Rap3 ? | waresee | Nokia Base Band 5 ( BB-5 ) | 3 | 03-17-2008 09:55 |
please help about n80 contact retailer what i will do i buy a new rpl | software2all | Nokia Base Band 5 ( BB-5 ) | 11 | 06-05-2007 10:12 |
