![]() | #211 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Unknown Age: 40
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | Quote:
its ok as you know jaf only able to backup pm in local mode. and if you backup crt you can have certificate of NPC and some others.. there won't be any simlock backup in JAF CRT backup. so pm backup will repair SIMLOCK STATUS.(that's in first post also) backup rpl will repair IMEI.(that's in first post also) and security test is fail then we can repair with sx4(authorizing phone) & modified pm(which hold only field1 and field309)(that's in first post also) if you know or not new security base bb5 call SL2 have 2 simlock information in eeprom(PM) field 120 hold provider,country & counter information. field 308 hold simlock crypted information but if your simlock show perfect and imei is perfect so only problem is authorizing phone which can be done via sx4 and write modified pm.(that's in first post also) ps: you have universal box? | |
The Following User Says Thank You to stanner_austin For This Useful Post: |
![]() | #212 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jul 2005 Location: Germany Age: 47
Member: 159805 Status: Offline Thanks Meter: 1 | i am shortly from giving up... SX4 Auth is always showing ERROR,..blabla and if its accepted, my jaf is hung at pm[309] last record [22] i uninstall jaf and intall it back again, but still same problem... really dont know why now PS:unfortunately i dont have UB,.. |
![]() | #213 (permalink) | |
you just post here what is your phone status now.i mean contact service or anything else problem when u start phone with battery? and post here JAF self test results WHICH ONE FAIL? | |
![]() | #214 (permalink) |
Member: 159805 Status: Offline Thanks Meter: 1 | The phone just suddenly came out from cont.retailer,.. its a magic ![]() ![]() today i just back home and make a self test and it passed, until these 2 are fail ST_CMT_APE_WAKEUP_TEST ST_MBUS_RX_TX_LOOP_TEST is it ok? if not, how to repair it? last jaf log IMEI plain: 354829020477240 IMEI spare to net: 3A 45 28 09 02 74 27 04 IMEI SV to net: 33 45 28 09 02 74 27 14 F2 LOCK STATUS: PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 my phone is baaack ... thks stanner_austin but btw : CONFIG KEY: 0000000000000000 is still like that,.. is it ok? Thankk youuu Last edited by stanner_austin; 02-16-2009 at 16:23. Reason: extra msg removed. |
![]() | #215 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | its ok for normal phones. you can check if phone work perfect more then 10min and charging calling work perfect means your phone is perfect. config key is normal for factory unlocked phone as i know. to say thanks only press thanks button no thanks post allowed. |
![]() | #216 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: Inside iPhone Age: 40
Member: 643010 Status: Offline Sonork: 100.1612806 Thanks Meter: 2,856 | N73 startup failear my n73 is startup failear LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23806F after i unlock with BB5_PRINCE_v3.01 LOCK STATUS: PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 also imei good but problem is same any solution pllssssssssss thankssssssssssssssssssssssssssssssssssssssssss Last edited by cts2007; 02-16-2009 at 22:32. |
![]() | #217 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | @cts2007 you should know that if your sp area is damaged or watchdog is on phone won't accept authorization (sx4).. so in this case even you repair sp area and phone work perfect it WILL BE OFF OR RESTART AFTER 10 TO 30MIN. in your case phone is on CONTACT SERVICE its need to be authorized to rewrite modified pm which NOT POSSIBLE BECAUSE watchdog is ON. so simple solution for your phone is BUY ASK 2 RPL. and stop asking already posted question. spend some time in READING ALSO. |
The Following 3 Users Say Thank You to stanner_austin For This Useful Post: |
![]() | #218 (permalink) |
Member: 643010 Status: Offline Sonork: 100.1612806 Thanks Meter: 2,856 | now gooooooood!!! my N73 is now goooooooooood !!! backup CRT and PM 308 with JAF Erase full flash with 16MB erase Full Flash with last version firmware Write Full PM Write CRT backup RPL Write PM 308 backup Write Full PM again then downgrade with this version 4.0750.31.2.1 after unlock with JAF_Nokia_BB5_Unlocker_v1.00 ater my mobile is goooooooood ![]() ![]() i used only JAF box thanksssssss thankssssssssss thanksssssssssssss |
![]() | #219 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: India/Malaysia
Member: 641058 Status: Offline Sonork: 100.1589325 Thanks Meter: 140 | 6630 write rpl problem after full erase i do full flash and restore rpl when write rpl she show some error see this log Phone is in: Local mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 12345610654321? IMEI: 12345610654321? Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_format.fg BOOT OK... CMT Send NPC Certificate CMT Send Variant Certificate Phone Type: BB5 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.97V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 35762*********** Simlock send - NO DATA IN RPL!!! SuperDongle send - NO DATA IN RPL!!! but imei ok and when we write simlock field in pm set hang and not respond and become shows only nokia without light after few second disappear all log here pls guide me sp log before restore imei backup Phone is in: Local mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. Production serial number Product code Module code Basic production code Flash code Order number Long production SN MCU SW V 04wk47_m_v14/09-02-06/RM-1/(c) Nokia. PCI RFIC 150a160e DSP pb04w47v26 Retu 32 Tahvo 41 IMEI: 12345610654321? ============= Set Flash mode for info ============= VBat is 3.96V Vpp pin has 1.31V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_format.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 12 blocks ------------- SYSTEM_ASIC_ID( APE ): 17100701 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): 02BFA84822CBEEB252E2A6FF4719FBF337C2C839 ROOT_KEY_HASH( APE ): 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM_ID( APE ): AB5E4ADB27A06946 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006000C192101002100 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000341 PUBLIC_ID( RAP ): 07D00001E1BE4F57357F3D4D419A7132805AAED2 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): E9EFF4BFAA5393217CA6B17755FC3E14 ROM_ID( RAP ): F28A211FAC901AEE --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22FA 0000 0011 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: APE Type: NAND Flash Index: 0 Flash: Samsung, 00EC 0035 00A5 00BD- UNKNOWN BLOCK ============= Set FBus mode for info ============= VBat is 3.98V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 12345610654321? log after restore imei backup Phone is in: Local mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 12345610654321? Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_format.fg BOOT OK... CMT Send NPC Certificate CMT Send Variant Certificate Phone Type: BB5 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.97V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. IMEI: 35762********* Simlock send - NO DATA IN RPL!!! SuperDongle send - NO DATA IN RPL!!! info log after restore imei backup Phone is in: Local mode Model: RM-178 ( RM-178) V 04wk47_m_v14/09-02-06/RM-1 (c) Nokia. Production serial number Product code Module code Basic production code Flash code Order number Long production SN MCU SW V 04wk47_m_v14/09-02-06/RM-1/(c) Nokia. PCI RFIC 150a160e DSP pb04w47v26 LCD 4555540 APE SW Core V 6.03.08/13-02-06/RM-1/(c) NOKIA. APE Variant V 6.03.08-Arabic/13-02-06/RM-1/(c)NOKIA Retu 32 Tahvo 41 APE HW 256 APE ADSP SW 52041 IMEI: 35762********* |
The Following User Says Thank You to sphameed For This Useful Post: |
![]() | #220 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Dec 2006
Member: 419750 Status: Offline Thanks Meter: 6 | Hello, I have N91 with fault "Contact service".I did self test (SIM_Lock + Security failed) and I checked IMEI (12345...). So I erase the phone 8MB_Erase+8MB_EE_Erase, then I load newest software version for phone product code (2.10.00),because I rebuilt IMEI by Phoneix, After that steps phone come up IMEI 1234... and Config and Provider with 00000000, after disconected and reconected phone again to JAF, Config Key+Provider chnaged to FFFFFFFF, so I repair that by BB5King and I did Self Test again and SIM_LOCK and ST_Security was passed. I switched on phone and phone is working with IMEI 12345... (I can make calls), but when plug in charger, charging not working. Now I rebuilt IMEI, and I wrote good PM ([1],[309]) by SX4 auth,Factory reset,but ST_Security is Failed now and phone come up with fault "Contact provider". I tried many times wrote different PM with same result. Please, any idea, how to fix that phone? Thanks Regards G. |
![]() | #221 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,089 | @GabeIE first clear me with how u rebuild imei? u own sx4 with fpsxx? if yes then u don't know how to do sx4 and write modified pm now because your phone imei is just fixed now? |
![]() | #222 (permalink) |
Member: 419750 Status: Offline Thanks Meter: 6 | I rebuilt IMEI by Phoneix by FPS-21+SX4, but I can't calibrated that phone, because I don't have CU-4 (base for calibration). So I tried fix that phone by JAF. Yes, I fixed IMEI, but when I did Self test , ST_Security is failed after IMEI rebuild. So I tried wrote PM by JAF with SX4 auth, but ST_ecurity is still failed after I wrote good PM (I tried wrote just [1],[309] and full PM). I read in some post, that problem could be in HWC and Variant in RPL, becauese when I looked at my RPL back up (Plain format) I didn't find these parts. Thanks Regards G |
The Following User Says Thank You to GabeIE For This Useful Post: |
![]() | #223 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,528 ![]() | I wonder if anyone have working bandlock data rpl for Nokia 6301? Is it possible to change band to this phone as explained in FAQ? Thanks in advanced! |
![]() | #224 (permalink) | |
i am specially collecting as much bandlock data as possible. so if any one have he can share so i can upload to free link posted at first page. @GabeIE old phones never have this i think, or area is not readable with normal method i guess. but as soon your phone firmware authorize its should accept modified pm. and 90% it should repair. if same after accepting modified pm then you need to downgrade firmware to test phone if its working or not as many results show it should work. | |
![]() | #225 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,528 ![]() | Hi, i have read the entire first post and have change bands succesfully many times for other models, but now i have a nokia 6301b (BB5+ i guess RM-323) that i need to convert to 900MHz, thats why i am asking for this file, if i ever get this phone with 900MHz (6301) then i will read the rpl for you to have it, but so far no luck finding it, thanks in advanced. |
The Following User Says Thank You to y3kt For This Useful Post: |
Samsung T509 lock for all providers | mapalma | Samsung Flashers, Software, Firmware. | 6 | 01-02-2009 12:44 |
New last flowchart for repair bb5 contact retailer | morteza-icu | Nokia Base Band 5 ( BB-5 ) | 0 | 09-26-2008 17:33 |
How to know BB5 Contact Retailer from RPL or Rap3 ? | waresee | Nokia Base Band 5 ( BB-5 ) | 3 | 03-17-2008 09:55 |
please help about n80 contact retailer what i will do i buy a new rpl | software2all | Nokia Base Band 5 ( BB-5 ) | 11 | 06-05-2007 10:12 |
