08-12-2007, 18:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | FINAL MANUAL FOR N95 HAMMER CLIP working prefect! tested 1) FIRST BE SURE THAT VERSION OF N95 IS :V 06WK41V23.4 17-04-07 RM 159 (C) NOKIA BY PRESSING *#0000# ON PHONE .IF DIFFRENT YOU NEED TO FLASH TO CORRECT VERSION BEFORE PROCEEDING USING MT ,JAF,UNIVERSAL . 2) NEXT YOU CAN MAKE BACK UP CRT308 + CRT .SO IF YOU TRY 3 TIMES U CAN RESET IT BACK AND TRY AGAIN .(MOST IMPORTANT STEP) 3) DISASSEMBLE N95 AND SOLDER WIRES AD0,CLK,GND 4) Power On phone and wait until displays goes OFF (make sure that you will cancell all intros etc) 5) Enter #pw+123456789012345+1 6) Press button and enter # from keyboard 7) Restriction OFF and phone will reboot 8) IF EVERY THING IS OK .PHONE WILL BE UNLOCKED AND YOU CAN REMOVE WIRES. I ATTACH HERE NOKIA DISASSEMBLY AND ASSEMBLY VIDEOS FOR N95 FOR NEW USERS http://rapidshare.com/files/48562499...USERS.rar.html IF YOU GOT COUNTER KEY BLOCKED (3/3) EVEN YOU CAN ALSO UNLOCKED COUNTER KEY BLOCKED WITH DEJAN N95 HAMMER CLIP YOU MUST USE DIRECT SP UNLOCKING FOR THIS YOU WILL NEED DEJAN BB5 UNLOCKING FREE SOFTWARE EASYLY AVABILABLE ON INTER NET F BUS CABLE AND JAF .JUST INSTALL COM PORT EMULATOR ON THERE AND CONNECT THROUGH FBUS CABLE N95. ALL YOU MUST DO IT'S CREATE PSW FILE WITH WHERE CODES ARE LOCATED(ANY CODES WILL BE ACCEPTED) AND NAME IT WITH IMEI OF YOUR PHONE. READ PHONE THEN AND CHECK IF ALL SIM LOCK ARE NOT CORRUPTED - IF ALL ITS OK. YOU MUST JUST PRESS BUTTON ON DEJAN N95 HAMMER CLIP AND THEN HIT SP UNLOCK BUTTON IN SOFTWARE - RELEASE BUTTON ONLY WHEN SOFTWARE WILL WRITE DONE THATS ALL. ENJOY BR CELLULARHUT |
The Following User Says Thank You to rajan nishchal For This Useful Post: |
08-12-2007, 21:12 | #10 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | and it works perfect without any soldering see here http:///vbb/showpo...4&postcount=33 B.R., Raskal |
08-13-2007, 02:40 | #12 (permalink) | |
No Life Poster Join Date: Feb 2002
Member: 9428 Status: Offline Thanks Meter: 120 | Quote:
Best Regards, Amit. | |
[wanted] n95 hammer clip or crazy clip | fr3nsis | Wanted Products | 5 | 01-15-2008 00:03 |
n95 hammer clip | fr3nsis | Sell ur Old and Used Stuff | 0 | 12-02-2007 14:04 |
*** N95 Hammer Clip Not Working *** | moni108 | Nokia Base Band 5 ( BB-5 ) | 61 | 09-10-2007 12:23 |
N95 crazzy clip, working prefect! tested | leviswang | Nokia Base Band 5 ( BB-5 ) | 19 | 08-16-2007 10:12 |
*** Dejan N95 Hammer Clip Clarification Needed *** | moni108 | Nokia Base Band 5 ( BB-5 ) | 6 | 08-08-2007 09:20 |
