12-05-2004, 22:41 | #1 (permalink) |
Junior Member Join Date: Nov 2003
Member: 45161 Status: Offline Thanks Meter: 0 | Flashing the 6630 and also..if anyone has a new firmware for this phone and can send it to me! thanks for reply bye |
12-06-2004, 19:08 | #4 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | No. DKU-2 can not be used for flashing. and PKD-1 is only protection (also stored algos) u have to have FPS-8 if u want to have original nokia flashing device. or u can buy Twister/Griffin/JAF etc.... |
12-06-2004, 19:22 | #5 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @ Yoda_Brno quite misleading... 6630 can be flashed by using DKU-2 cable and latest Pheonix (with PKD-1). 6630 firmware is updated via USB ADL flashing which does not require an FLS-4 or FPS-XX connected. ADL Flashing is similar to ADSP, so no need to connect chinese datacable... just need DKU-2 on USB port. As of now,, only Pheonix can flash this phone... other third party flashers does not support this phone yet. As of now, I think no one can unlock this phone... B.R. X-Shadow |
12-12-2004, 13:53 | #8 (permalink) |
Freak Poster Join Date: Jan 2003 Location: on earth Age: 40
Member: 20633 Status: Offline Thanks Meter: 193 | hi, iīve already flashed 6630 with DKU2! but 2nd flash failed... 1st flash: from 2.39.126 to 2.39.15 -> FLASHED OK! 2nd flash (just for fun*gg*) from 2.39.15 to 2.39.129 FLASH OK, POLLING PRODUCT ERROR!! i donīt know why, maybe phone cannot be downgraded??? so now phoenix donīt recongnize phone, in LCD only appears NOKIA, after few seconds phone switch off (there is also NO BACKLIGHT!!) so please,donīt flash your 6630, until nokia has corrected their ADL flash concept... your phone will thank you greetz hk2k2 |
12-13-2004, 07:09 | #9 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | 6630 cannot be downgraded as of this moment.. I have also 1 dead 6630 which was accidentally downgraded due to pheonix autodetecting the product code and producing the default flash files will a lower version. I am still working for a solution for this... very strange since the service bulletin states that to fix downgraded phones, all you need to do is to reflash it with the original or newer firmware. The question is, how to reflash it when ADL flashing requires phone to be in Normal Mode? Downgraded phones cannot get Normal mode by themselves. So I suspect that flashing these phones require a special procedure or equipment... maybe FPS-10 + AD-23FS. Or maybe just need special battery to put phone in Local mode, then call Normal Mode via some MBUS command. For those interested: Corrected 6630 Pinouts for Chinese Service Cable: [Camera Lense] ___4 1 ___5 2 ___6 3 ___7 [Battery Terminal] 1 - VPP 2 - MBUS 3 - GND (USB BLACK WIRE) 4 - USB RED WIRE (USB Power 5+) 5 - USB WHITE WIRE (USB TX) 6 - USB BLUE WIRE (USB RX) 7 - NC for new phones which are not yet damaged,, just use Simple DKU-2 + Normal Battery. B.R. X-Shadow |
01-08-2005, 17:18 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Jul 2002 Location: LONDON, UK Age: 47
Member: 13583 Status: Offline Sonork: 100.1613271 Thanks Meter: 139 | wow.... i bought pbb and flashed 6630 all went ok.... thanx x-shadow for answering my call..... now my next step is to find out the solution n how to revive 6630 killed by pbb by using pbb also... maybe yes maybe no.... who knows again tnx -shadow... |
01-11-2005, 05:25 | #12 (permalink) | |
Junior Member Join Date: Feb 2004 Age: 49
Member: 52318 Status: Offline Thanks Meter: 0 | Quote:
I take it that a Phoenix Black Box does the job of a PKD-1? Or am I wrong? And, if one were to theoretically obtain a version of Phoenix that does not require a PKD-1 to work, could one then flash the 6630 with just the DKU-2 cable? One more thing, I've had a .pdf file from Nokia detailing the flashing procedure for the 6630 using USB and Phoenix, and the procedure mentions installing the "latest RM-1 data package". Is this the 6630 PC Suite? Or am I barking up the wrong tree? Basically, I need to remove the T-Mobile branding on my 6630, i.e. a one-off flash. I don't need it unlocked and won't be doing any more phones, so if it's possible to do with just a standard DKU-2 cable then I'd love to know. Many thanks | |
01-12-2005, 21:18 | #15 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8030 Status: Offline Thanks Meter: 3 | @ f@nnypad - RM-1 is the Nokia name for 6630 - check the label on the back of your phone (close to where the imei is printed) and you'll see RM-1 Just means you need the latest 6630 flash files. Although how you flash them seems difficult at the moment many flashers "killing" the phones - i'm hoping for a solution for UFSX-3 soon |
all tested on the 6630 | Special@gsm | Java, iOS, Android, Symbian development | 33 | 03-30-2020 10:34 |
flashing the Nokia 6630 | Frantic_ua | Nokia Base Band 5 ( BB-5 ) | 2 | 03-29-2007 05:28 |
the new flash for 6630 | momayaz | Phoenix Black Box | 24 | 04-28-2006 21:25 |
Japanese and the 6630/6680 | westernphreak | Nokia Base Band 5 ( BB-5 ) | 2 | 08-04-2005 01:51 |
error in languge packeg for the 6630 | momayaz | Phoenix Black Box | 4 | 07-23-2005 16:18 |
