Flashing Problem In Nokia N-72 Hi Guys, I have a set with white screen no Boot. I flash the software but problem persists in middle log is given below please suggest to me that what is actual problem? ---------------------------------------------------------------------- Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v42.2 13-04-06 RM-180 (c) Nokia. HW version: 5001 PCI version: RFIC version: 150a160f DSP version: rolf_espresso_05wk07v28 Retu version: 32 Tahvo version: 52 Production serial number: CJH130269 Product code: 0531541 Module code: Basic production code: 0530940 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359400008914078 IMEI spare to net: 3A 95 04 00 80 19 04 07 IMEI SV to net: 33 95 04 00 80 19 04 07 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0531541 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50741401.V12 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: English,Trad Chinise,Indian Done! Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 00020001 <=> SPANSION -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\35940000891407_CRT_backup _1623103.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\359400008914078_CRT_backu p_1624103.pm Done! Backup LCK OK! Reading SW version...05wk07v42.2 Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101012200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 21B00019C23F5151BA8EA989A5EEC3B2BE1A0077 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 00020001 <=> SPANSION -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 5 seconds... Sending CNF Data... APE blocks present in flash file but no APE mcu detected in phone. Aborting! ----------------------------------------------------------------------- |
only software problem...........flash with higher version... |
