11-02-2009, 14:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | How can i unlock Nokia 6790s RM-492 locked to 31017 i have jaf, genie, HWK and universalbox. here is the log.. Code: Searching for phone...Detected P-KEY: 90000BB4 P-key nokia module version 01.02 Init usb communication... Found MCU SW version: V 09w17.03.22 13-05-09 RM-492 (c) Nokia HW version: 5000 PCI version: RFIC version: DSP version: APE SW Core version: 03.22 APE Variant version: 6000.01JI01.01 APE Test version: rm492_ENO_x_2009wk22v0.010 Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12676. Production serial number: RHM587779 Product code: 0568166 Module code: 0203991 Basic production code: 0568165 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 353221030172675 IMEI spare to net: 3A 35 22 01 03 71 62 07 IMEI SV to net: 33 35 22 01 03 71 62 17 F9 LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 311180 Block 4: Lock 1: CLOSED -> Lock Data: 310410 Block 5: Lock 1: CLOSED -> Lock Data: 310980 Loading INI list... Detected P-KEY: 90000BB4 P-key nokia module version 01.02 Init usb communication... Reading product code... Product Code: 0568166 Searching for JAF saved location of ini... Checking path: C:\Programme\Nokia\Phoenix\Products\RM-492\ Searching for default location of ini... Checking path: \Products\RM-492\ Searching for JAF saved location of ini... Checking path: C:\Programme\Nokia\Phoenix\Products\RM-492\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
11-02-2009, 15:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, 6790s is Rapido PA_SL2, you can unlock using universalbox or genie clip ; ) Both can calculate unlock codes. P.S. make backups before unlocking : ) Regards, Ali |
The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post: |
11-04-2009, 21:03 | #3 (permalink) | |
Member: 753732 Status: Offline Thanks Meter: 252 | Quote:
i need german flashfiles for this phone, dou you know where can i find it? i check all support areas, cant find anything, and i check Navifirm too... | |
02-08-2010, 18:28 | #7 (permalink) |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | here u can find cable info :http://www.4shared.com/file/19407809...lector_50.html |
The Following User Says Thank You to techno-gsm For This Useful Post: |
hi all, how can i unlock nokia 1680c-2b rm-490 | achi_nokia | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-30-2011 15:01 |
ub supported unlock nokia 6790s RM-599 | alsaber | Universalbox | 2 | 03-03-2010 02:22 |
can i unlock nokia 6790 with ub | sr8787 | Universalbox | 1 | 12-14-2009 08:37 |
NOKIA N97 RM-505 LOCKED TO HUTCHINSON 3g:) | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 11-05-2009 15:57 |
