how flash nokia 301 rm-839 hi : how flash nokia 301 rm-839 because the driver wants !!! what is a flash box? |
please help me no one comment? |
yes , i have a flash file but , i can not flash my phone |
Hello, You will need NokiaCareSuiteForStore-2013_20_5_3 and flash files. Work in offline mode, use option programming>refurbish. Tested with 301 rm-840, successfully updated to ver 02.51 rm-839,840,841 are supported with that nokia care suite ver. |
I need nokia 301 RM-839 02.33 ppm I need nokia 301 RM-839 02.33 Russian ppm pls help thanks |
Thanks sopla4ever Nee arabic ppm Thanks sopla4ever Nee arabic ppm RM-839 02.33 pls help |
good luck |
Your can Download and find all product code file easyly if you have cyclone ,,, |
In NCS when I try recovering NCS tells me that the connection is lost. It does not start to flash my device propperly. I do like this: 0. Firmware files are downloaded using NCS Data Package Manager (however, the files I downloaded is for another product code) the NCS is closed. 1. Phone is disconnected and turned ON 2. NCS is started in offline mode and Production Support Tool for Store is opened, programming>recovery 3. File>open product>301 rm-840 (my device is not rm-839 but it should not make any change in the procedure?) 4. 301 is plugged in and the start button is pushed. Then after a while (the status bar is not moving at all) it says that the connection has been lost Any ideas of what to do? |
I need nokia 301 RM-839 02.33 Turkish ppm pls help big thanks |
Plese Hindi flash file urgent |
i need direct download link |
