how flash nokia asha 503 RM-920 hi ii want to know if someone succed the flash of asha 503 RM-920 , i try with best, hwk, advance but none. need help. thk |
Install WinUSB Nokia Connectivity 7.1.182.0 Try............. |
SIMILAR PROBLEM,cannot connect the phone to the computer properly,it connects for a second and the phone restarts with charging. installed Nokia Connectivity 7.1.182.0 and its restarting with charge. cannot connect with NCS. |
i installed nokia pc suite,i suppose pc suite is not compatible with asha phones.it is still not working,connect flash mode and phone start with charge. i am using xp sp3. please guide with how to install drivers correctly or there is a way to do dead flash differently with NCS. |
FLASHING TOOL there are many, you may not need to use the NCS, you can choose to use the Phoenix cracked version because support WIN XP. RM is what ? I can help you search for a version that supports it Phoenix |
Thanks for reply, appreciate your assistance.just to avoid confusion..latest asha s does not use phoenix ,nokia released NCS.for nok 503 NCS V5-1414 and above release. My question is why am i strughling to connect only nok asha 503 to flash with ncs.i have flashed many windows and bb5 without any struggle. I have also tried on windows 7 machine and nok 503 fails to flash in dead mode. |
Although I did not go to test this model But I can tell you really be able to use the cracked version of Phoenix In Phoenix.ini manually add models About NCS Why not use DEAD MODE No Comment |
with best download Nokia_WP8x_NXP_MTKx_Asha drivers from support then install, then connect the phone without battery until best detects , it will show u that connect battery after detected then ur gud to go! |
