Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-13-2005, 11:43   #16 (permalink)
Mehdi Ghorbani's Avatar
Member: 103931
Thanks Meter: 31
very nice work this code before(*+call+3+pw) u must full factory reset(*#7370#)
Old 07-13-2005, 14:21   #17 (permalink)
abadon's Avatar
Member: 134869
Thanks Meter: 8
*#7370# work
*+3+green buton
work
Old 07-13-2005, 18:12   #18 (permalink)
Member: 160666
Thanks Meter: 7
silly question but is this work for every nokia?
Old 07-13-2005, 23:49   #19 (permalink)
Member: 10964
Thanks Meter: 285
silly answer try it on your 5110 and see
7370 code works on all nokia symbian
the format procedure works only on some nokia symbian models (does not work on 7650, 3650 etc)
hope it is clear now
Old 07-20-2005, 16:41   #20 (permalink)
Magdi's Avatar
Member: 14287
try this
*#7780#
may be useful
Old 07-22-2005, 02:02   #21 (permalink)
Member: 23397
Thanks Meter: 10
and this one *#7780#
Old 08-05-2005, 09:12   #22 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Yes
*#7370# works Perfect
Old 08-09-2005, 05:33   #23 (permalink)
Member: 126806
You are right "leespud", The Process of formating in "OFF" Condition only works with 6600 and now with 6630 and 6680, not with other symbian phones, all others need to use *#7370# code, and of course the set should be "ON" with SIM,,
Kyun Buddy
Old 05-14-2006, 18:34   #24 (permalink)
Member: 244008
Thanks Meter: 3
tostefo u know 7710 doesn't have key pad so how do we format and which keys do we press?
thankx in advance
Old 05-14-2006, 18:37   #25 (permalink)
Member: 244008
Thanks Meter: 3
Originally Posted by tostefo
hah ....no one explain to you......ok i will.....insert battery at phone.....pres *,green/call/ key and digit 3....hold them together down and press power on botton....hold them till phone says formating.....then release....it's work with all simbian phones /for 9xxx and 7710 there is other combination/.....regards
pls can u give me the combination for 7710 pls
thankx in advance
Old 05-14-2006, 18:45   #26 (permalink)
Member: 244008
Thanks Meter: 3
yes u are right but can u pls give me the code to format 6630,6680,7710
thankx in advance
Old 05-14-2006, 19:33   #27 (permalink)
Member: 244008
Thanks Meter: 3
Originally Posted by taaz
Type *#7370# or
*+3+call key+power key
pls can u give me the format to format 7710
thankx in advance
Old 05-16-2006, 14:44   #28 (permalink)
Member: 271084
but it doesnt get rid of the software in the fone memory
how can i do full factory reset to nec411 cellularman FuriousGold 0 08-17-2008 07:59
u600 how to full factory TCJUDAS Samsung Flashers, Software, Firmware. 6 08-01-2007 18:50
6230 cant set to full factory???????? kcgckc2002 MT-BOX 0 09-02-2006 14:45
How to set 6650 to full factory setiings? selfone69 WD2 & APE (Symbian Phones) 0 11-02-2004 16:10
how reset v51 to many wrong entered nck unlocktel Motorola Old Legacy (EMMI) 0 04-22-2003 17:59
Page generated in 0.19219 seconds with 9 queries
