let start with at command reset counter project 1 Attachment(s) let start with at command reset counter project i found in the forum mny idea about send recived code from server for bb5 with blocked counter when i uses at command uses hyperterminal or AComportDemo at command for entering NSCK code is AT+CLCK="PN",0,"XXXXXXXX" NOKIA GSM AT COMMAND SET Call Control ATA Answer Command ATD Dial Command ATH Hang Up Call ATL Monitor Speaker Loudness ATM Monitor Speaker Mode ATO Go On-Line ATP Set Pulse Dial as Default ATT Set Tone Dial as Default AT+CSTA Select Type of Address AT+CRC Cellular Result Codes Data Card Control Commands ATI Identification ATS Select an S-register ATZ Recall Stored Profile AT&F Restore Factory Settings AT&V View Active Configuration AT&W Store Parameters in Given Profile AT&Y Select Set as s Powerup Option AT+CLCK Facility Lock Command AT+COLP Connected Line Identification Presentation AT+GCAP Request Complete Capabilities List AT+GMI Request Manufacturer Identification AT+GMM Request Model Identification AT+GMR Request Revision Identification AT+GSN Request Product Serial Number Identification Phone Control Commands AT+CBC Battery Charge AT+CGMI Request Manufacturer Identification AT+CGMM Request Model Identification AT+CGMR Request Revision Identification AT+CGSN Request Product Serial Number Identification AT+CMEE Report Mobile Equipment Error AT+CPAS Phone Activity Status AT+CPBF Find Phone Book Entries AT+CPBR Read Phone Book Entry AT+CPBS Select Phone Book Memory Storage AT+CPBW Write Phone Book Entry AT+CSCS Select TE Character Set AT+CSQ Signal Quality Computer Data Card Interface Commands ATE Command Echo ATQ Result Code Suppression ATV Define Response Format ATX Response Range Selection AT&C Define DCD Usage AT&D Define DTR Usage AT&K Select Flow Control AT&Q Define Communications Mode Option AT&S Define DSR Option AT+ICF DTE-DCE Character Framing AT+IFC DTE-DCE Local Flow Control AT+IPR Fixed DTE Rate ServiceAT+CLIP Calling Line Identification Presentation AT+CR Service Reporting Control AT+DR Data Compression Reporting AT+ILRR DTE-DCE Local Rate Reporting Network Communication Parameter Commands ATB Communications Standard Option AT+CBST Select Bearer Service Type AT+CEER Extended Error Report AT+CRLP Radio Link Protocol AT+DS Data Compression Miscellaneous Commands A/ Re-Execute Command Line AT? Command Help AT*C Start SMS Interpreter AT*T Enter SMS Block Mode Protocol AT*V Activate V.25bis Mode AT*NOKIATEST Test Command AT+CESP Enter SMS Block Mode Protocol SMS Commands SMS Text Mode AT+CSMS Select Message Service AT+CPMS Preferred Message Storage AT+CMGF Message Format AT+CSCA Service Centre Address AT+CSMP Set Text Mode Parameters AT+CSDH Show Text Mode Parameters AT+CSCB Select Cell Broadcast Message Types AT+CSAS Save Settings AT+CRES Restore Settings AT+CNMI New Message Indications to TE AT+CMGL List Messages AT+CMGR Read Message AT+CMGS Send Message AT+CMSS Send Message from Storage AT+CMGW Write Message to Memory AT+CMGD Delete Message SMS PDU Mode AT+CMGL List Messages AT+CMGR Read Message AT+CMGS Send Message AT+CMGW Write Message to Memory |
hi pleased to meet you i could do with your help ! Hi m8 ! i,m trying to understand how i enter my unlocking code by using a cable i,ve only just posted a reply to somebody about bb5 counter resetting but you seem to understand the concept better than anybody i,ve spoken with so far . can you guide me step by step how i can enter my code into my n73 i have tried understanding your txt but it still confuses me especially the bit where you say "xxxxxxxx" is that supposed to be the unlock code that i need to enter because my code is 15 digits long that vodafone has sent me its as follows #pw+975239285328143+1# ? also i,m having problems connecting my phone to enter the commands i even have a jaf box and still i can,t work out how you do it ??? hope you can help me i,d really appreciate it if you can . thanks in advance !:confused: |
Hmm.. this needs investigating. Z. |
I think you need to downgrade your phone to earlier version, so it can accept at command new version have at disabled I am not sure, it's just a contribution |
hello |
sorry but u are spending ur time and brain (i think) with nokia bb5 simlock state we have two steps: - communication with phone - recalculate simlock data you are studying comm related issues, it's ok but if you solve this, you will only have 2% of the work the hardest thing is to understand simlock data structure at commands are public, but nobody will reset counter only with at commands wbr thecult |
hi again ppl! hi ppl ! Thanks for all the replys we def need to investigate more into this subject and like i said all i want to do is enter my unlocking code by cable i don,t need to calculate anything i have the code off vodafone but i,ve used my three tries so now its looking like by cable is the only way now ? so anybody with a step by step guide that shows me how to enter the code by cable i,d be really grateful . its strange how nobody really mentions this method and the only other options are to send the file off to nss or fedral one thanks to djx aswell for the faq guide for active ports its interesting reading ! |
for reset counter no free solution ;spend monney for calculate ask file to rpl;and don t dream my chawki;) |
what do u understand about AT command and recalculate simlock its so far from ur mind so if u have something to tell us do it or go to repair ur dct-3 fones @Chawkizz u have to focus in recalculating simlock cause it is the hard thing and u have to bypass the protection |
Chawkiz_gsm have u test ?? br wink shafeeq geo mobiles |
as i have understood, BB5 simlock structure have primary counter try (which is blocked after 3 wrong tries) and secondary counter try (which is blocked after 10 tries), am i wrong?:confused: if you get your counter blocked after 3 primary wrong tries, you still have possibility to enter NCK code with some trick Here we are talking about how to enter CORRECT NCK GIVEN BY OPERATOR in a phone which have primary counter Blocked this is where come terminal mode trick it's not about Unlocking (means finding code, or disabling simlock status) Enter Correct NCK with terminal mode = reset counter I think we should try DOWNGRADE + TErminal command and see results BR |
NO WAY RPL files calculation only via nokia server, must have account and for this time all accounts blocked;) and no way to compare ask and rpl file [FILE]..VERSION=1..[REBUILD_DATA_OUT]..DATA=4962107FF80BF48BE7F8B60AC728C2C3A7DF7BFDEA7 BD8F2E8214CCA12CC61F26FCD8E3154FE4EAA76CBB08DAF97B 7C2B53A5F3F835AD9F15C1733A2435CC569A1F41C94BA43F64 211E37578CE7C950E5F302B62D95D35E4E6BE63B78A63BACD9 76698CBF6EA97B9101721BF41518204D938F32825B6DECC345 3187A32E773F2BC1B4607668B7046C5DCB015E2D14D6FEF564 47C22CCC6262B9F919B3FAE3FB80000D5D53E0E307A474DA56 43F796C0B30786039063E21B919E28C3D6D48BEFFB3683864F 91004FDB38B226F812BCCD968434C792AB9A2C30F956CE6833 2653553B60D6ADBAA36A988D82CE29D396A69985B6EE997EB9 D3CB1D5B54604C9DBEA95EEBB9C5CF96A53C8035F36442BC07 49161CD04068E3E19F8BFDEA346667AE2FD68B389D0EAA80DF 8A2ECD337EC196C8D9D5A4A48A7532607092B4E2E6C806C99A 3598CAD641990374A006A105870B1AD102FB6C85A750C7D493 27416FACC11DF5BF611610CE8EF3E3D451474534F3B9EA00D0 EF6E76CDE686952059D5439BC573DCFA98687F3631038D63BF FC75A31699B43EDCC62BB4D0072B9A6E2D7A3D9CA281950BBC C80A2C1C49A38078DD12AFCF021C3003B952E1759EF2404829 481A8652CA71EC4020B2D68656D3527A6B810CDF077CA7A1F4 6C90C4843A50C3ABAC0658DBCC9D458B770610D8929EFC240E 1D26F6264ECD8153D785D6A0D094CECA81B560BE679A3189D5 D6DBE59DD3118C2F95C3FEFEF2108E2FC0B3E4B7FA02876B5A 6257755546CA8C3E77FFC668B3BDE519F7D86F9B299FD7F15D 5FD2B940D08A5DCDC69CF4A7B6DB88186C7D658537F5EAFB0E 353ADFA6E5BBAAC09EE3F723B0854B014097FD7AEE78F31E0E 314FE223187077767C32C41E7BF8A20D65BABA7505321CBC56 DD8964D5D63F26D4D6B19A5BE66E8C49F2CB860D0D8EAD8A65 061B8F59B7B5FBE32EDB1769755CBB6ADAFAA9E11ED0176F58 98512B34E898C92AB712C835163113BD8166B70076DCFA4E2F F3861F6BF9F3EF40313EEB30152DBF1A86848A0CCBF99E5E38 52E73D8C6CDC897087B5455E4AB79F5BB786840A2456167D8A DD48B3D7CDE13B17C67F05371C525A8136D325ED789740DB07 79D6D6CA67CA06342DD7F9079A626B94887A22F0578CB0199B 6FB473A88745E019F5D88ADDC888D8790E301BB565CDDCC9AD E3E45D3A44CA105E52AFAF5C2A4279863C9A932EF6E5C284FF 5E50E3A6D623E801DA3A8497CEF659303BB4921737D3BCDDB0 CACA618F8C429421981E4293EB19037F690945E2369DE5D28B B767C7B0E8E3C7E2528CF9D3BA41983F796110F0EC6BE9D7A1 812FF6186D79551EA8FE32FBDCBA141E736929A92331A14B03 E521C222015A6AC4E415C553BDF8941BA5054E3CF8A6562C46 C358F3C8740185D4E6F88428E2E4EFD23DBB39E35950BAE482 ADA535091380339CFA22114A8147721987999620DA67D7371B 730E61953180CF99FABF2F8330660F2793FE6C20EA1F0D7321 89FA243511749969255FCCF20A87B98F6A57D90D33C28AC9A3 4FD7B43F9B14C13DB09FD28C07CAB5E6AFD1DA44E43C7EAF82 FCE17F560C979E5FE062ECB129EF200B54CA7376D5FC68D48D 338769FC9DE7EEEA6F33B5DE98C6F2468F9FD6D2494FD313A6 A699CCE7BF2416AD62DF504C7B3D2173AC93A527753612739E BDBF7A21149A8A4ABCA4A8E35E685A1F7BCD7298BEA957006D 7D6DFDA0948CF654B1CA94623FE6D209B3E532D17996D7C16B A8A78576ED35A9535969B496310F70CFA1433F92EE2E78994E 2748FEF111FB6C5B4226B0644EA6929254F3EC7AE808828B19 3F5F606B7684F075B23506C909156E14ABF0CA7513BCA73129 5D618DF929A9A78750E71163FA8DE7C36AAF27BFB192849AE3 A75D7313248CAFC3CC8C064A01CD66B3656FD1C43BF564DF8D 8D6BF689D19FC4744BB19622A721061D4EDF0B849EE866632B E01BBA8ACFD5DD87488702325C412D019AD4A3271A6B20F1B5 DC65DC2E35B151D3DF2D397F41B5CD7C894050B1E0CC5EB4C6 1C4C7C387CFF1D295F504CCBBE60EC67F65751ECDE73524FC1 21F635D3B86CF212D9F05499627884EA83DFDDB107EB9D93E4 987C06B71204B1688A681E727F903D7A12C1BC3E56B5B917E0 460B28F086E29282324F8E87B0C97B5C955434F34827930B49 1B747A0AB1BE40CDFB603E9FBA8D526B00952AF40643263E0C CABBD294E45E2950D004E2F7CE635D3624B82C680FF3C0E740 E3D02337969F072B830279E4F4F0699E62C06C3CB762A1D48F 6A684BB9F2B820420926548A209EB86187E0796F83E01BAF51 35DDB79991B067047AF949BB853CF8474E20F34398786B70C6 3933A99191E910397DCE52BB5866DCA8716F994D912F945580 2D9D91E0312C891447436C2014AB1D3F9AD3D5F6696D060BB4 1897BDD5BAD83C1E0860039A3C36005DB714117B78C64EA9AE C62BCE07C354FE7C2290608B408FE8D8D2F05A4853409784EA EE79E2690BFA09C3AE8B1151C4B9F71735715E36EAE2F2A940 571AB6C262BCB91BAFA45520410B14FE1F1D92F897E9E5F5DC 8DABD4689585BD25912571A0AF7D10AEF9A29956DC67D957EC 50C9721A66D293708072E70AB684F3BA56263600E03D2F6367 40913C2F55714D922407126B5567D12BD3D7F324566BC26931 2B864BF8D69DF8F743429B08352E4081E74C227F998C7D0.. [FILE]..VERSION=1..[REBUILD_DATA_OUT]..DATA=4962107FF80BF48BE7F8B60AC728C2C3A7DF7BFDEA7 BD8F2E8214CCA12CC61F26FCD8E3154FE4EAA76CBB08DAF97B 7C2B53A5F3F835AD9F15C1733A2435CC569A1F41C94BA43F64 211E37578CE7C950E5F302B62D95D35E4E6BE63B78A63BACD9 76698CBF6EA97B9101721BF41518204D938F32825B6DECC345 3187A32E773F21CCA15CA49A72F00A96545D4C2680BFE02699 E0F941A05ADCEAB0F3FB664C59421E035D5B7EBB3A891119DD 6D6F1B028B10E654B39401E5CCE283341D75462F9DC715E7B5 F962A6CC298EA4F3599C8CB4389F0956310CD78FB2F9E4BD50 34DC1590771B3F2F8CA11DBBE658D68554EA0E7C59BB2058CA 3442A939698344D88BC35F40C8F0F66D1D5FB4A8F6C43044EC E1E63FD35EC8D731A0E46B4AC85C3CE69A5DAA329B82871F12 E571DF53CD146D0F5056DA7F2261A2D74833C7BFEA0BF9983F EFD14B5B3930D005911EC5895FE5F2EF86B9898E6752D37A03 B89664337E342C5E2CA79DE62FB2DA2AC5507C63584798952D 75ECF5707EA10238DB8EE57AE79EE37B8F74B146F6BC0576E8 0322196EB595257564EEBEC26A12F2DDD57284106F5E90FB01 C1C95B895A3BA9B7A070E28C99BC48AE954F05D484A29BC144 62D994DF588543B0F02B03D952ED2E0943BA2F5303F755FC67 BD6674651B53E59444AA15AFB124527383870F7E78C5C2BC7B 6E42B0BE49312971C490F275D3B4E9B16DC5DADF31201C38D3 7D5983201002785F9EBAD2EA859AB917B3FF51460AF02F7935 F01C3FA03F62DEA16378AF5ED4F34FA63A072CBE41A865FC57 6785EF43D493E583604C9A6D61C0CAE755DC61B9A224F434DA 4EF35BC60CE0E678C5CAC17F849DFFD241A59145B1AB4D7515 11B350583ED652239D1B2198F5575E11B1F8F140246E8F749D 33141F725E4FB8E878CC3C2D0E0B95B6824E632D7A6FC6B95F 5248DCC86E66CF3A65CB75D1299AA6A74480F8D433FDB721B5 6FEAAE43FF4C857786DD7A81D4D01FF21D8B699AFE9EA67E35 BEE66DE772E871E1E94AD263C6CA9A698CAACFE575B9B16683 E518B3A2F613A3FAAEBC23BA6D8CC6819323076D06802C7919 0E019BD8DE9CE6AEC7DCA1FE44CA2F2BA14B46A23E270D5AB6 1A1420DBB5033F4513ADEABD5E61967D30F49BC65C39DFB2A8 6C721F93BB4C56A5C0C749FAB95144F6294E62E030DD803DFF A2FC71B469C4B0D18555911A723B3A2E9C70A3CB3D8977ADAB F8E58F405E0DAB33D4ECF2949095E2D665E8684A878B352653 BC09F47347583704540C52339B9FBAE3114C1D8D6D9B972400 6026E77123000AAED60DE50EE54EE51DF625EE99AFDDC5D9FF 4FB52F0AE5291784E6692B041544D78AEC383138DE1ED40B66 915C35E40C77B8EA0859F2D7ECEC5DC3609731C847429C9F42 664AE7942595B940CD1D4E1A9F1AAEFFC417219820D27BC545 C823D5091380339CFA22114A8147721987999620DA67D7371B 730E61953180CF99FABF2F8330660F2793FE6C20EA1F0D7321 89FA243511749969255FCCF20A87B98F6A57D90D33C28AC9A3 4FD7B43F9B14C13DB09FD28C07CAB5E6AFD1DA44E43C7EAF82 FCE17F560C979E5FE062ECB129EF200B54CA7376D5FC68D48D 338769FC9DE7EEEA6F33B5DE98C6F2468F9FD6D2494FD313A6 A699CCE7BF2416AD62DF504C7B3D2173AC93A527753612739E BDBF7A21149A8A4ABCA4A8E35E685A1F7BCD7298BEA957006D 7D6DFDA0948CF654B1CA94623FE6D209B3E532D17996D7C16B A8A78576ED35A9535969B496310F70CFA1433F92EE2E78994E 2748FEF111FB6C5B47E6D46AF061828CF5B7A1DBF8E539656D CF2A38A1B8204CE8AD0CA4A282F7B11C0FABD5226F3F59D377 FCBF14EA6B15A9E3BA47D0A23B773AE341BDDE601D3ACEBD16 CD7A111223D5D06B311D7019CB412CA22184E130BFE5B48779 7B42EA13C7C31363D7650EA77087A2FA4E13325A861F633D90 41627B62B287387BD9ABBC340FDEBC0584CD5FED24D7B6B528 15D486023E8D2407EFC9B346AAE8A3F0972EB238AED4242ABE A224F449938CE492AA4E13AA558D192F0CE5F4A093BF26195C 685E92280BC98C7A248A60DB1EE4CDBF15623D46DF07231ECC 3661131E62248B252550904AE8A0C499A14 33331347174CCC521970186FCDE2F7A9886D9FDA8B33AD1315 090B7CEE6DDCC60D68230182575292F9227B80E80DA433090F 01D9D6A5FE1B8ECB30E1BF3A6FD5649AB345B36932CE555F8C 66CE84E5964729DFD5D752BF5DEC1FB6F5BB0E1E871D0C1612 4C4A9601E0ACFFFFAFE3D7271F46EA1AF7B74AB4391362263D 8DAB45A8F31F1F01E8B10F0FA0243FBAA0D8E721A342060B8C 6CD066327D437BCFAFD745B72E949C84AEF1F41E4B2F5B539D 55463F400624FF7321C43C40B7BB1BCE1098D5FD51E0818BD8 E4B0B3E17682B261351C649DD8C94EDC70F720DC6865297BA8 FCDC57A57C54259FB1CBB97597F82A6FCFAF42AC4C291AD682 5938B8993E20BA893B0B65B0F1C3432F92235BC8699A69D46D 41F0BB846671CEBBEF33F742A457A0E7BED88017FDB8779C9E 64B397B524A93E6F31B499E2F9E4E984405876BEFD6394D5CD B4A824C2FE7741F867339EE7B4C040B38A8BB8FD0801F9DD4C 7597441A3590F91CA7E41062F842565122686DCC7087CFA048 09ACFFA23AD1211BACE79554BBDA9B114E3FE07B91935F6EC0 AECB32D35E14.. |
I CONFIRME THX EMINIMENGSM FOR THIS INFORMATION. |
I have 6630, with counter blocked, and with NCK code from operator MCUSW ver 2.043 have "phone to network lock" facility enabled but i tried to downgrade the phone with latest UFSx release, and I got "mobile can't power, contact your retailer" wrote backup PM, phone don't power at all upgraded again to original version 6.050 and phone come to life if any one succeeded downgrading 6630 from 6.050 to 2.043 let me know, and wich tool you used BR |
