09-17-2007, 23:51 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 375397 Status: Offline Thanks Meter: 0 | N70 - After BB5 Unlock, strange problems :| I have N70 ME, and I tried to unlock it using Dejan software, bb5 and dku-5 cable, everything went fine. Phone was unlocked, but then I did something, I don't know exactly what And I get message phone start up failed etc. when I insert sim card Sometimes it starts normally, but nokia startup animation is very slow, something like 1 fps, also symbian works very slow and there are some errors And in the end of problems, simlock is back :| Here are screenshots from Dejan unlocker, and NSS hope this helps to find out what is wrong with that phone I will be grateful for help ! Thank you very much, thinkbot |
09-19-2007, 03:00 | #6 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | use jaf sir in TAB settings check CRT 308 and CRT BKP flash it with no mcu after flashing your rpl will automatic save the click CRT TOOL check write rpl and restore the original that save in folder your phone is back to live..... |
09-20-2007, 14:47 | #7 (permalink) |
Member: 375397 Status: Offline Thanks Meter: 0 | Ok, I went to mobile service And, they downgrated the software and it's still the same. I think it can be hardware problem, Here is what I did before When I get my phone, charging wasn't working. I've unlocked it using Dejan's software, it worked fine Then I used electronic multimeter to check what is wrong on main board with charging, meybe I accidentialy connected something wrong when I was checking Then I closed the phone, and turn it on, errors appeared, animation was slow etc. In the end, when I opened phone again, I found that it was fuse problem, I replaced it with tin, charging works, but still animation, and other errors So, meybe someone of you had similar problems ? or meybe you know what could have I damage ? Please help, it's very nice looking N70 Music Edition to repair Regards, thinkbot |
09-20-2007, 15:03 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | hi mates i have tried flashing many phones with this n70 me try this and flasfiles i hope this will help solve your problem.. http://rapidshare.com/files/37286867...5.3.0.zip.html |
09-21-2007, 13:13 | #9 (permalink) | |
Member: 375397 Status: Offline Thanks Meter: 0 | Quote:
It didn't help, it was some kind of special firmware or something ? Do you have any idea what's the problem could be ? As I described, animation is slow, menu is slow on start, but after I open it it works good, and after about 3 miutes phone turn off automatically. Any ideas ? | |
09-23-2007, 23:55 | #11 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 312740 Status: Offline Thanks Meter: 0 | Quote:
One my friend has same problem wit n70,after,when hi charge phone in a car. | |
. : : 3110 strange problem : : . | khm050 | Nokia Base Band 5 ( BB-5 ) | 6 | 12-21-2009 15:26 |
Genie BB5 Unlock - strange Problem | Dodger | Genie Universal | 3 | 06-14-2009 15:04 |
.: Nokia 1208 Strange Problem :. | billal1050 | Nokia Hardware & Hardware Repair | 10 | 05-09-2009 18:06 |
.: Nokia 1208 Strange Problem :. | sujan1050 | HWK | 15 | 05-09-2009 17:54 |
.: Panasonic G500 Strange Problem :. | Jani-Jan | Hardware Repair by brands | 7 | 05-07-2003 06:43 |
