N70 Camera Flash Light Always On Handset Is Dead any body help me please yester we are face n70 water lock handset just we clean the the handset after cleaning when we have to put the battery only camera back flash light is on we change the boot ic but the problem become same |
in u have get aprogram n70 flashlight delete it and then try to format it by using thse nombers *#7370* and then enter the unlock code and it may works |
do u try 2 flash the phone. chk the OMAP IC ,clean water & rehot this is. BEST OF LUCK, JHON. |
where is omap ic in n70... please explain with picture..... thanks in advance |
1 Attachment(s) http://forum.gsmhosting.com/vbb/atta...1&d=1199265853 dis solutions will soft ur problem u try it...... WinD:) |
hey i have the same problem, and the picture is of the phone with the white part of the keypad on the handset removed right? and after i remove it and see what I see on the picture, exactly what do i do? |
hardware problem.check rap3g omap. |
how do I check them? I know where they are but what do I do? |
hei u can check your cpu.you can change it. |
how would i know whether its the cpu, the rap3g ,or the omap causing the problem? |
Thanks anybody, This solution sometime ok, sometime not ok hand set. BR, Jakariaj |
arunkumarmyneni. |
____________________________ camera flash camera flashes digital camera flash |
