N70 System Error and Freeze Hi, I'm having trouble with my N70. A few minutes after booting up I get the message - "System Error". The phone then freezes. Any suggestions? Thanks in advance. |
formating do the job most of the time |
Yes format phone use same trick like 6600 will fix problem. I had 2 prototype Nokia phones not released yet 3250 and E60 they have same problem and I fix this. regards bounty |
Just flash your phone from phoenix via any connection with new version i.e. 3.05 and restore factory defaults it'll be work fine. WBR Haseeb |
n 70 system error 6600 code dosent work *#7370# 1000% works try it |
i hv same problem my set is new when on it after few second phone then freezes.i hv flash the latest vesion alr but still same got other solution to fix it.....:confused: |
not work with formatting and also with flashing wat have to do some one can tell us v r awaiting for this solution Salman Ahmed |
k first check for virus then format ur phone then format ur card to and the update phone software version it will be fine i to facked same problem in n70 remove ur card while u update ur firmware |
my nokia n70 gallary problem |
