n85 only vibrate on powering on!!!HELP PLZZZ http://forum.gsmhosting.com/vbb/../ubb/icons/icon4.gif HELP Plzzzzzzzzzz n85 no display checked OLEd screen, changed flex, changed display ic with normal ones. At first the phone was getting display but display was not good when changed the 2 display ic it results in no display,no sound and no light????? should i place specific display ic or wat??????? plzzzz help SOS:confused::confused::confused::confused::confus ed: |
hi;friend flash phone with good ENO fils may be flash not good download latest version instal end flash with HWK use cable 7pine and post ...;) |
i done one n85 with same problem as your's! 1- Backup Rpl (All Certificates), Better to use mx-key with ufs interface. 2- use ufs for doing SX4B, you can also save certificates with this. 3- write good pm file without field 120 and field 308 (modified pm). 4- Restore certificates and do SD R |
IF you get white screen problem then Change display ic with new one |
flash with HWK use cable 7pine |
N 85 1st REPLACE OLD DISPLY IC,(make sure flex and lcd are ok) 2nd CHEAK SOFTEWERE, 3rd change boot ic, problem will be solved. |
Change flex it will solve your problem:) |
