01-08-2009, 14:58 | #2 (permalink) |
Freak Poster Join Date: Dec 2007 Location: GSMinators LAND Age: 40
Member: 661523 Status: Offline Thanks Meter: 205 | yes it is! you can also unlock 8gb but then you need credits. No credits or test points needed for normal n95! br misiu22 |
The Following User Says Thank You to misiu22 For This Useful Post: |
01-08-2009, 18:13 | #3 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | as I know N95-4Gb is same like common N95 with las firmware 30.00.15 then you can unlock with Mt-Box by 2 ways: - NoTp license: warning. Only if you have modified N95 fbus cable with stable signal (stable localmode) or you can damage certs and you will have a perfect dead N95 - Via old Tp: Mt-Lite supports 30.xx versions fine. If your N95 is not 30.xx version, upgrade it better. regards |
The Following User Says Thank You to thecult For This Useful Post: |
01-09-2009, 12:51 | #4 (permalink) | |
Insane Poster Join Date: Nov 2008
Member: 898777 Status: Offline Thanks Meter: 5 | Quote:
Have you ever unlocked this model by this method? Where is the modification for the n95 cable? Thanks for your answer. | |
01-09-2009, 17:49 | #5 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | yes, I have unlocked many N95 (as I understand N95-1 = N95-4gb) via USB common cable but remember: CONNECT ALL GROUND POSSIBLE if you use this method about n95 fbus cable modification, you need to put 1n4001 diode, I have tried with 1n4006 (should be same) but not works u have scheme here: http://forum.gsmhosting.com/vbb/atta...1&d=1229511841 |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
help with n95 4gb | pachicoo | BB5KING | 0 | 11-26-2009 19:36 |
N95 4gb display light | ngaia | Nokia Hardware & Hardware Repair | 4 | 09-03-2009 08:41 |
not suportted version n95 4gb nooox team | belli42 | NoooX Box | 6 | 06-02-2009 19:17 |
n95 4gb unlock problem please healp | fazi52 | BB5KING | 1 | 02-10-2009 06:38 |
