08-17-2013, 04:52 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2003687 Status: Offline Thanks Meter: 0 | Problemn with Nokia 5230 The bater runs flat in a few hours and it should give about 480 hours. Energy profiler show it to use about 0.25 amps or 0.8 watts in stand by and also it only lasts as long as you would expect for something drawing about 0.25 amps. It should be drawing about 0.003 amps according to my calculations. I have tried the obvious stuff to lower energy and done a hard reset by 2 methods but no real change. Seems may a fault on the phone or a virus or a bad update?? Please help!!! |
08-17-2013, 05:45 | #2 (permalink) |
Member: 2003687 Status: Offline Thanks Meter: 0 | Hello boys and girls!!!! I am not sure whether I feel elated or stupid!! I have had this problem for age over a year anyway and tried everything, at least I thought I had anyway. Anyhow I just though I would have one last go at going through the menus and I stumbled into the 'location' application and found all the positioning methods were switched on!! I though I would turn them off and see if that helped!!! And did it help??!! Yes it did!!! Even when I turned them off I could tell the phone felt a bit cooler. I went back into the energy profiler after the screen had blacked out for a while and had a look at the readings. It had dropped right down to, I estimate, about 0.07 watts. But unfortunately it has now gone back up to about 1 watt Oh well it was good while it lasted. I wonder if maybe some server went down for a short while? |
08-17-2013, 19:34 | #4 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | seems u r non technical person , phone have some shortage in circuit . better to contact any nokia care center for repair ur set . |
08-18-2013, 03:47 | #5 (permalink) | |
Member: 2003687 Status: Offline Thanks Meter: 0 | Quote:
You have to remember I am in the UK, a repair might be cost effective there but I doubt it would here, so I would have to send it to India which would cost, plus I do not think it would be a good idea because they might not be able to repair it, plus I can get by as it is until I get a new phone. I do not like the phone much because it is hard to stop it making chargeable calls without you knowing. The camera is good though. Anyhow I kind of doubt it is a short circuit, I think it would be peculiar to get a short circuit which drew almost exactly the same current/wattage as when the phone was in use for talking. Incidentally can anyone here supply me with the figures for the current draw when a call is being made, or at least the range into which those figures would fall. I guess I could find out myself by making a call, but that would cost me lol Will have to wait until someone calls me But surely some of the folks here know the figures? Also I have seen a number of people reporting pretty much the same problem, so do they all have the same fault? Last edited by esbo; 08-18-2013 at 03:53. | |
08-18-2013, 20:03 | #6 (permalink) |
Member: 2003687 Status: Offline Thanks Meter: 0 | I took it apart last night to have a look inside, it seemed to look OK, but when I put it back together it was dead. Seems I broke it However I had anther go at putting it back together and this time it worked. Maybe the fact I was sober helped. I still have to put the plastic slider back in as I forgot that (deliberately), but at lest I will not have to undo any connections to get it back in. |
08-18-2013, 22:19 | #7 (permalink) | |||||
Member: 2003687 Status: Offline Thanks Meter: 0 | Personally I do not think there is a problem with the hard ware, my problems seem very typical. Here are a selection of comment I found about the phones battery life from 2010. Quote:
I have *never* seen anyone report solving the problem - says a lot does it. Personally I think the battery lasts a while when you first get it, but as you install stuff on it it gets worse and worse. The trouble is you cannot install some stuff, I have tried it. It says installed and it removes the file, but when you check the application is still there, as the file is removed you cannot 'uninstall' it again. Last edited by esbo; 08-18-2013 at 22:27. | |||||
08-18-2013, 23:36 | #8 (permalink) |
Member: 2003687 Status: Offline Thanks Meter: 0 | "The trouble is you cannot install some stuff" above, should read "The trouble is you cannot *uninstall* some stuff". I am pretty sure it is a software issue, something is running on the phone, I would go as far to say these phones are designed to do to this. The changes of a phone have a short circuit that allowed to phone to still function are rather slim in my opinion. Electrical devices either work or they don't, the si not much in between. And example is when I dismantled the phone and put it back together, it had a fault, but it was not a fault which drew another 1 watt. It was a fault with killed the phone. So it's all or nothing. For ".:SARCAR:." to say I am a non-technical person is true to a certain extent, I am not a technician, I am an engineer, I have a degree in electronic engineering!!! |
