11-11-2006, 18:00 | #1 (permalink) |
Junior Member Join Date: Jul 2005
Member: 165687 Status: Offline Thanks Meter: 0 | N70 Firmware update issue Thanks in advance. |
11-11-2006, 18:27 | #3 (permalink) |
Member: 165687 Status: Offline Thanks Meter: 0 | I now have version 5.0638.3.0.1 18-09-06 RM-84, its a real bugger coz I thought maybe doing a factory reset would sort it out but because I have to input a pin number on restart the factory reset of green 3 and * does not work it just keeps asking me for my pin, does anyone know of another way to factory reset? I have backed up my data before I tried updating the software so I am not bothered by a factory restet. Cheers |
11-11-2006, 18:58 | #4 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 288085 Status: Offline Thanks Meter: 0 | Quote:
Or You can reinstall actual firmware also via NSU (checkbox reinstall)... Or if You want to experiment, You can try to reflash your N70 to N70 music edition (http://forum.gsmhosting.com/vbb/showthread.php?t=347725) Write if it's useful for you. | |
11-11-2006, 21:27 | #5 (permalink) |
Member: 165687 Status: Offline Thanks Meter: 0 | Thanks for the repy, I used Euro1 so maybe I will try the music one although from what I read there are some small minus points with using the music version, if someone can let me know what code I could use for an N70 bought in the uk on T-Molile tarrif, the silver and black casing, other than Euro1 I would appreiciate it. Will also try doing the reinstall as you suggested, and then restore again, maybe the restore I used had something to so with it?http://forum.gsmhosting.com/ubb/confused.gif Cheers |
11-14-2006, 15:18 | #6 (permalink) |
Member: 165687 Status: Offline Thanks Meter: 0 | Thanks for your idea daso, it worked a treat , I think my backed up image was corrupt which is what was causing the problem but I just reset everythig from scratch which after all the stuff I had installed and tested it was probably better I start again. Great forum here guys keep up the good work. Cheers |
M310 Firmware backup issue | cmscms | Samsung Flashers, Software, Firmware. | 4 | 02-18-2010 13:44 |
N70 Strange network issue | LVVINE | Nokia Base Band 5 ( BB-5 ) | 0 | 03-02-2009 16:46 |
Firmware upgrade issue | Mohtech | FuriousGold | 1 | 09-08-2007 04:45 |
Updated to new n70 firmware from nokia and now I can't change my fonts | jadedjeanne | Nokia Base Band 5 ( BB-5 ) | 2 | 06-11-2007 16:54 |
N80 firmware upgrade issue | rakiii | Nokia Base Band 5 ( BB-5 ) | 17 | 12-11-2006 19:16 |
