Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-03-2009, 22:57   #1 (permalink)
atukhi's Avatar
Member: 92401
Thanks Meter: 48
Need help flashing N70 with JAF
Hi,
i try to flash a N70 which is not power on anymore and JAF shows following Error:
JAF version 1.98.63
Detected PKEY: 900xxxxD
Card life counter: 99.87%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Programme\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Programme\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Programme\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Programme\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Programme\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Programme\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
PPM Flash file: C:\Programme\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01
APE Variant file: ?
Backing up CRT data...
Setting FLASH MODE
Error sync the phone...
Failed to backup CRT...
Backing up SIMLOCK data...
Setting local mode...
Failed! Aborting!
Failed to backup LCK...
Manual mode selected, version can't be checked!
Booting phone...
Old 07-04-2009, 07:49   #2 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
check the cable its the cable problem
Old 07-04-2009, 07:51   #3 (permalink)
experttelecom's Avatar
Member: 914898
Sonork: 100.1597109
Thanks Meter: 117
Try to use gpg cable
Old 07-04-2009, 08:06   #4 (permalink)
pooja_19's Avatar
Member: 326069
Thanks Meter: 19
Originally Posted by atukhi View Post
Hi,
JAF version 1.98.63
APE Variant file: ?
Setting FLASH MODE
Failed! Aborting!
Booting phone...
Hi friend
1) check the cable its the RX.TX BSI 7.5K rasitor problem
2) boot SMPS ic 8 pin
3) APE_ regulator 1.8V chek
4) RITU BSI chek
5) RAP 3GSM Re hot or change slove enjoy!
Old 07-04-2009, 08:17   #5 (permalink)
atukhi's Avatar
Member: 92401
Thanks Meter: 48
If its cable problem, how comes i get the Test Mode???
plz help me n70..with jaf abousalma007 Nokia Hardware & Hardware Repair 1 08-08-2009 18:21
Guide to flash n70 with jaf francogsm JAF Xtras 1 09-19-2007 06:43
Page generated in 0.18503 seconds with 9 queries
