Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-03-2008, 10:25   #1 (permalink)
Member: 301327
Thanks Meter: 2
can i unlock bb5 phone with usb cable
can i unlock security code for bb5 phone by using usb cable with JAF box
Old 10-03-2008, 11:58   #2 (permalink)
Registered User
Member: 234917
Thanks Meter: 160
You will need the security code to connect the phone in USB mode if phone security is turned on.
Old 10-03-2008, 17:46   #3 (permalink)
Member: 618649
Thanks Meter: 12
you can do this easily with usb cable and nokia phoenix service sw, but only with phone which can be flashed as a "dead phone"
start flashing the phone as a dead, after the main flashing is done, phone will reboot in test mode, quickly disconnect usb cable, cancel flashing, restart phoenix, change connection back to usb, scan for product and after that make full factory set
tested on 6300, e66
Old 10-03-2008, 19:24   #4 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
u can also use jaf craacked with usb cable and perform factory default...but u have to bot phone on test mode, for this i connect phone to bb5box for battery connector and usb cable to pc usb port.
luck
Old 10-04-2008, 08:29   #5 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Thanks Meter: 151
yes,
use Vbat, bsi and -ve in F-bus cable, make local mode
then connect usb cable read secuirity code easly.
Regards,
saif.
Old 10-04-2008, 08:30   #6 (permalink)
newfoundghori's Avatar
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
you need to modified your usb cable....!!!
Old 10-05-2008, 13:15   #7 (permalink)
khan_mobiles's Avatar
Member: 476667
Thanks Meter: 56
how to modify usb cable
any diagram plz provide it
The Following User Says Thank You to khan_mobiles For This Useful Post:
Old 12-14-2008, 16:13   #8 (permalink)
persianuser's Avatar
Member: 516318
Thanks Meter: 27
plz guide for modifing usb cable
Old 12-14-2008, 16:37   #9 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
just use working usb cable................................
Old 12-15-2008, 00:48   #10 (permalink)
mariochines's Avatar
Member: 283371
Thanks Meter: 13
just conect resistor 7,5 in GND and BSI batery contacte and use NSS and make factory defalt
Old 12-15-2008, 01:10   #11 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 315
or you need the MTBOX use cable USB and GND BSI and vbat
Old 12-15-2008, 05:57   #12 (permalink)
Member: 41063
Thanks Meter: 9
for unlocking the sim it would be great to have a jaf box share...read this thread
http://forum.gsmhosting.com/vbb/showthread.php?t=517910
Old 12-15-2008, 06:13   #13 (permalink)
Member: 800937
Sonork: no
Thanks Meter: 56
JAF version 1.98.61
Detected PKEY: 900
Card life counter: 0.52%
WARNING! Update your Pkey to increase life counter!
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.0.2.0
Starting Card UPDATE...
11:09:48.781 Error: JAF dongle init failed
raskal
How To Unlock BB5 Phones Whit USB Cable ? fusarista MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-18-2010 15:41
plz mx-key add feature unlock bb5 model with usb cable amanhalwara MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 01-28-2010 13:10
Can i unlock the z140v with Usb cable? Pacman15 QUALCOMM Models (3G) 7 12-09-2007 23:23
Page generated in 0.19177 seconds with 10 queries
