03-09-2010, 12:42 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1143486 Status: Offline Thanks Meter: 0 | 5800 black screen and restart please help me with this i have nokia 5800 while i am using it the screen get black an vertical lines with pink and purple then the phone restart i did software to the phone tried so many software versions but no changes , the same problem So any one help me with this? |
04-20-2010, 11:58 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: PAKISTAN TO PORTUGAL
Member: 720201 Status: Offline Sonork: 100.0000000 Thanks Meter: 643 | its hardware problem try to search you will find proper solution i think place some little piece of magnet inside near lcd |
04-24-2010, 14:24 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | thx for your reply, but customer told me that his phone was working good before i flashed to change language.. now phone without simcard is working very good, but with simcard it restarts each 5-10 minutes and just before restarting screen becomes black with vertical purple lines moving.. do you really think it's hardware problem ? thank you! |
04-24-2010, 17:50 | #9 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | hi all already i faced this problem______ but my phone is 100% ok! solution___ 1. change display ic ( be carefully because lcd connector here, first give steel cover upon the lcd connector) 2. if not work you need another way______ just give paper or tape in the lcd male site ______ ( you need it for more good feting ) and insert it in the lcd connector. than must solve your problem! don't forget to press thanks button |
The Following 4 Users Say Thank You to akashrana_sky For This Useful Post: |
05-20-2010, 04:33 | #10 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | i am sure its a software problem i have had same experience it is usally caused my downgrading the version of the phone which is not supposed to be done to confirm this post log with mxkey and u will discover it has a super dongle problem search forum u will find a solution on how to fix that |
06-14-2010, 02:40 | #11 (permalink) | |
Member: 1012165 Status: Offline Thanks Meter: 116 | Quote:
The Following 2 Users Say Thank You to tonywireless For This Useful Post: |
06-20-2010, 11:56 | #13 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | hi i successfully fixed this problem on a 5800 but the little problem i have is that when the phone goes on stand bye mode and i use the side lock button to release it, it shows normal unlike before when it goes multi colored,but now when it goes on stand bye and i tap the screen (even when the key lock is disabled )it does not pick up i.e it does not show the normal screen instead it still shows black then occasionally multicolored till i push the side key lock keypad that is when it shows normal,pls help what do i do to have a complete and permanent solution.thanks in advance |
04-30-2011, 13:00 | #14 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: turkey Age: 51
Member: 174769 Status: Offline Thanks Meter: 19 | Quote:
I solved my problem; insert a piece of paper to lcd connector with the lcd flex solution is succesfull Many Thanks bro!... | |
n 95 black screen and no light | makchou222 | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 23:58 |
v3 black screen and no boot mode | RamSon83 | Motorola P2k | 9 | 05-30-2009 00:38 |
Blackberry 8320 Black Screen and Red light | ownage | BlackBerry (RIM) | 3 | 05-23-2009 01:48 |
d500 black screen and "nothing more" | aafro | SWIFT Platform | 2 | 11-17-2006 19:50 |
R210 with black screen and battery low | azrine | Samsung Hardware Repair | 1 | 11-21-2005 18:32 |
