Nokia 3110c Music player "No files Found" I have Nokia 3110c Music player "No files Found".. sir wats d problem.. how to solve |
flash in latest version................100 % solved in problem |
full flash using the highest version problem solved :) |
3110 c music files problem flash it with latest ver 7.30 your phone will be fine 100 % |
Thanks guys... Shud I use UFS?? or any other box would be best?? |
.. Quote:
full flash sir use this ver7.3 RapidShare: 1-CLICK Web hosting - Easy Filehosting |
did you try to format phone and memory memory card? if done so flash your phone. |
Respected Forum Members, I've the same problem with my Nokia 3500c.It plays files stored on phone memory.But for files on memory card it displays "No files found".I've flashed it with the latest Firmware version 7.21,but the problem is still there.Can anyone help me. |
thanks. |
only reset factory and format memory card |
just scan memory card with windows check disk utility and all will be ok |
UFS is enough to FLash 3110c to Solve No Music Files Found Error |
But After Flashing, Put Formatted Memory card in the Mobile. otherwise the same problem can occur again. So be careful. |
