Nokia 5130 xm after flashing with mx key giving this problem plz help??? Nokia 5130 xm after flashing with mx key giving this problem plz help i was trying to flash becaz of security code that i didnot succeed to remove with factory setting becaz there came error and i tried flasing but now situation is as below and mobile is dead plz help Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm495__07.91.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.20 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 09D0001798397F5633A6523B73A4866633FA4794 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase skipped. Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x000406C0, Result: 0010 Flashing terminated with error(s) in 28.312 s RX Buffer: C7012D0103CD000010000000F172 |
Try with 7.96 ver by usb. Br. Shashank |
Try with 7.96 ver by usb. |
thanx but now its giving error like this..... Changing flashing settings... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.96.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.96.ppm_s CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.96.image_s_red APE Variant file: NONE Detected P-KEY: 90011FAF P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 09.07.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... .....Error booting phone... Detected P-KEY: 90011FAF P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 09.07.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... ...........Error booting phone... Detected P-KEY: 90011FAF P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 09.07.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... .....................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Phone rebooted but not in flash mode... |
Dont post your P-Key ID in this post me... |
