nokia 5230 phone startup failed contact the retailer nokia 5230 phone startup failed contact the retailer Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5233 Software ver : V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI : 359343049750939 Ape Ver : V 51.1.002 APE Var : V 51.1.002V 51.1.002 V 51.1.002 APE ADSP: 256 DSP Ver : ICPR72_11WK13 APE Test: eno_version PPM : CNT : Product SN : MIN393787 Product code : 059B7J1 Base Prd.code: 0587948 Module code : 0204695 Long Prod.SN : 0 Hardware info======= HWID : 0310 Retu : 16 Tahvo : 22 Batery: 3695 mV APE HW: 256 Lock info =========== IMEI : 359343049750939 IMEI spNet : 3A 95 43 03 94 57 90 03 IMEI svNet : 33 95 43 03 94 57 90 13 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! any solution thanks ;) |
check imei i thinks um fault |
hard format ur mobile ur problem wl b solved |
imei is ok IMEI : 359343049750939 after sx4 and write crt with hwk Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 11 F6 Unable to read Lock table... :( IMEI DAMAGED!!! CRT308 save skipped... :( SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Damaged!!!!! PA_SL3 phone , SP_CODE_LEN : 15 |
i have i backup rpl file and full pm file sorry for my bad english |
All Nokia Update and Old Flash File Only here. |
