01-31-2010, 07:34 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: On Muhammad's Way
Member: 597789 Status: Offline Thanks Meter: 147 | 5130c Contact Service Solution (software) its easy.... 1. Cek if Superdongle is valid or not.... how??? you can use UFS HWK, MXKey or JAU... JAU is free to cek SD Valid or not... its no need connect to server... If SD is Valid... then you can solve your phone... If SD is not valid... seems there is no solution right now... waiting... just do backup you PM as Full PM (0-400) n backup CRT n CRT308... this maybe will help us in future...i hope... 2. do self test with any box if there is fail or not.... if security is fail.... do write area PM 1 an 309... need SX4... off course you need to connect to server that support SX Authorisation... like MX Key, JAU n others.... if Simlock is Fail.... create PM 120 with 7 block unlock n then write the PM into your phone... this operation no need connection to internet.... after that try to flash your phone with higher firmware (not sure if this operations necessary or not) Try to backup your CRT n CRT308 n Full PM before doing any operation in BB5 try this n post result... |
The Following 2 Users Say Thank You to Biocell For This Useful Post: |
01-31-2010, 09:33 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
i have 5130 contact service problem, sd is valid ,sl is valid,and also security test passed can u give any idea for that? | |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
02-01-2010, 03:54 | #7 (permalink) | |
Member: 597789 Status: Offline Thanks Meter: 147 | that SL3 phone is the phone that have protected PM120, 308 and firmware protected... so why i can wrote PM to this field 120? i dont know... maybe 5130 is not SL3 phone... this list of SL3 phone... http://forum.gsmhosting.com/vbb/showthread.php?t=910348 Quote:
01-06-2012, 19:21 | #11 (permalink) |
Crazy Poster Join Date: Aug 2010
Member: 1373202 Status: Offline Sonork: 1594079 Thanks Meter: 6 | nokia 3110c SECURITY_TEST failed! nokia 3110c SECURITY_TEST failed! MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0856FBE Using device: HTI, FW ver: 00.24, SN: 00007ECE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 22F0001728A07E565A49B32B9A53286E3404DDC9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35196303845512 Original Product code: 0550542 Bluetooth ID: 00247CAF33BF Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303845512-1 Product code: 0514950 Battery voltage: 4496 mV, current: 97 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351963038455121 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN note: allready use mxbox pm write fectory restor,,but same problem any body help kindly Last edited by atik_chowdhury; 01-06-2012 at 19:22. Reason: any body help kindly |
NOKIA 5130c CONTACT SERVICE | ami tomar | Nokia Base Band 5 ( BB-5 ) | 30 | 08-27-2011 21:03 |
nokia 5130c contact service any solution with mx key (ANSWERED) | sushilsoni2003 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 08-26-2011 18:03 |
5130c contact service full solution done | gsm junction | Nokia Hardware & Hardware Repair | 4 | 02-26-2010 21:13 |
5130c-2 contact service solution | kamal dhiman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-10-2010 19:35 |
