06-06-2009, 15:15 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | N73 Unlocking Error..SL Data is Damaged.. hi all.. phone has lock.. but sl data is damaged.. and not unlocking and not reapiring sl data by raskal 1.4 and zulea 2.1.. solution is rpl...? Code: JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Read Phone Info OK Operation time: 00:11. Successfully done. Thread phone exit. Code: Type: RM-133 Version: V_05wk47v61.1_09-07-08_RM-133_(c)_Nokia. IMEI: 357XXXXXXXXXXXX4020 Config Key: FFFFFFFFFFFFFFFF Key counter: 0/3 Cable counter: 0/10 unlocking post.. Code: JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-133_357XXXXXXXXXXXXX4020_Locked_Keycnt_0_Fbuscnt_0__V_05wk47v61.1_09-07-08_RM-133_(c)_Nokia.__06_06_2009__17_10_22.bin PM308 backup OK Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B1 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... Error. 0x10130103 ERROR! Operation time: 00:26. Done with error(s). Thread phone exit. repair sl zone log.. Code: JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-133_357XXXXXXXXXXX020_Locked_Keycnt_0_Fbuscnt_0__V_05wk47v61.1_09-07-08_RM-133_(c)_Nokia.__06_06_2009__17_13_57.bin PM308 backup OK Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B1 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... Error. 0x10130103 ERROR! Operation time: 00:26. Done with error(s). Thread phone exit. |
06-07-2009, 11:33 | #7 (permalink) |
Freak Poster Join Date: Apr 2006 Location: DAMMAM Age: 43
Member: 262523 Status: Offline Sonork: 100.1611482 Thanks Meter: 288 | here is your answer u can try this try the best http://www.4shared.com/file/10980470..._DARMILES.html |
06-07-2009, 11:38 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Just write a locked back-up of the PM308 of another N73. It will go in CS as Imei PM308 <> Imei OTP after this, using Cineck 1.03 repair SL (It will fix the imei 308<>imei OTP) after this Imei will be ok but config/provv=FFFFFF Unlock and will be OK.. Use version 1.03 not 1.04 BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-06-2009, 21:21 | #9 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | my frend me tu the sem problem i allredy tri all softs evrythink bet nathing hel the problem is sem 10 days i tri evri thing 1- rpl or 2- send tu servis gooooooooooood luk |
06-07-2009, 12:07 | #12 (permalink) |
No Life Poster Join Date: May 2008 Location: Greenhills,Philippines
Member: 771856 Status: Offline Sonork: 100.1582636 Thanks Meter: 793 | Sir use this one exe that all nokia unlocker Turn off your anti virus this exe have .Dll http://forum.gsmhosting.com/vbb/showthread.php?t=755065 In shell have bb5 prince |
06-07-2009, 13:02 | #13 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | maybe u wont believe me but pb was CABLE.. and SL Data is now correct.. and phone is working well.. thanx alot to everyone for everything... |
HELP-Dongle identification data is damaged, error code #65 | cupon | Infinity-Box | 4 | 02-17-2009 09:33 |
Dongle identification data is damaged, error code #32 | malek_bh | Infinity-Box | 5 | 02-16-2009 11:44 |
Dongle data is damaged,error code#65 | ashamsu | Infinity-Box | 6 | 02-06-2009 12:26 |
Dongle data is damaged,error code#65 | FullFlashPak | Infinity-Box | 2 | 02-05-2009 13:05 |
Repair error: Dongle data is damaged, error code #32 | DYNET | Infinity-Box | 0 | 12-17-2008 17:08 |
