Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-18-2012, 11:13   #16 (permalink)
Member: 1557159
Thanks Meter: 5
please any solicion x6 contact reteiler ??
Old 04-18-2012, 11:24   #17 (permalink)
SHIBLU's Avatar
Member: 537829
Thanks Meter: 96
1st back up rpl & pm.
then just do factory setting in any box.
if not done then flash with higher version.
check security area.
Old 04-18-2012, 11:25   #18 (permalink)
Member: 1557159
Thanks Meter: 5
Switch-off the phone (Remove the battery and re-insert it, if necessary). Now Press and HOLD the GREEN (Call) key, RED (Call end) key and the Camera-capture key SIMULTANEOUSLY. While still pressing the above three keys press the power On/Off key, hold them until phone boots up.
Old 04-18-2012, 11:31   #19 (permalink)
Member: 1557159
Thanks Meter: 5
This is how to format Nokia 5230, 5800, 5233.
Here is the step-by-step instruction:
1. Switch off your phone
2. Hold call key (Green Button), Cancel button(Red key) and camera together at the same time..and switch on your phone.
That's it.Enjoy Format complete.!
Hope it worked.!
Please rate and subscribe.,;
-http://www.facebook.com/informaticonavalmoral
Old 05-15-2012, 20:02   #20 (permalink)
Member: 1701010
Thanks Meter: 2
fixed .. twice
I did face this situation twice and solution was easy both times
the first case was that the battery connectors were a little lose
so I what I did was that I removed them and re-welded them back again
and that was it
the second case was treated with ATF after a clean flash with the latest version all what I did was to format drives like this:
The Following User Says Thank You to ojail For This Useful Post:
Old 06-12-2012, 08:48   #21 (permalink)
Member: 550428
Thanks Meter: 25
the battery connector works for my x6..
thankyou
Old 06-12-2012, 17:55   #22 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
Contact retailer solution in hardware
Betty ic fault
Change betty ic or tiggle it
Solved 2 phones
Old 06-12-2012, 19:01   #23 (permalink)
Member: 1769492
Thanks Meter: 5
Waiting for a response from his subject
Old 06-13-2012, 07:18   #24 (permalink)
Member: 838176
Thanks Meter: 57
bro,post handset info logfile
Old 07-08-2012, 08:52   #25 (permalink)
Registered User
Member: 1262367
Sonork: muhammedshafikulangaredat
Thanks Meter: 19
not working ..........
Old 07-26-2012, 10:59   #26 (permalink)
Member: 497896
and that was it
Thank you sir the bsi image worked for me
The Following User Says Thank You to nt57_1985 For This Useful Post:
Old 08-11-2012, 07:15   #27 (permalink)
Member: 621454
Thanks Meter: 30
nice solution dear good job
Old 11-25-2012, 13:36   #28 (permalink)
Member: 1478774
also check 3rd leg of battery connecter value called BSI ( battery sense. if show nothing call me ... 9212412274
Old 11-26-2012, 15:32   #29 (permalink)
mhassanrazabj's Avatar
Member: 485816
Sonork: 100.1623308
Thanks Meter: 18
the battery connector always works for me when log info are correct.
Old 12-12-2012, 07:56   #30 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
and that was it
thanks battery connecter works for me too.
Page generated in 0.23619 seconds with 9 queries
