Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 01-17-2007, 10:12   #1 (permalink)
Anno's Avatar
Member: 8360
Thanks Meter: 4
Phoenix error : MCU do not fit into storage devices on APE side
Hello !
Please help me , i have last FIA loaders, last phoenix sw , but when i try flash E60,.. i have error :
Flash: Prommer has detected that MCUSW contains area(s) that do not fit into storage devices on APE side.
HRESULT 0x8401b58c (-2080262772)
phoenix log :
eading data from phone
Reading phone information
Reading product type
Reading product code
Reading PSN
Get flash file names
Reading IMEI
Reading HW version
Reading flash settings from file(s)
Initializing
FPS-10 detected based on connection settings.
Preparing for file upload...
File 'rm49_m128_h20_km_prod_206180605_c00_combined.bin' loading is skipped: 1024 byte check-sum, name and size seem to match an existing file in the Programming Device
File: C:\Program Files\Nokia\Phoenix\products\RM-49\rm49_m128_h20_km_prod_206180605_c00_combined.bi n loaded successfully
Starting flash...
Initializing
Initializing prommer
Initializing
Flashing image
CU-4 already in FBUS mode.
Phone programming
BB Asic Index is: 01
Asic ID is:
17100708
Asic Mode ID:
00
Public ID is:
69489CFD0E50156EEACD525178F38EC2E68424BD
Hash:
49A97E826B93BA20B7ED0B082475C00500000000
ROM ID:
1DFD66132C872FD4
BB Asic Index is: 00
Asic ID is:
000000010000022600010006000C192101002200
EM Asic ID is:
00000232
EM Asic ID is:
00000352
Public ID is:
0A4002108CA34951EEF8C7BBB12F7BF39A07BF0B
Asic Mode ID:
00
Hash:
E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID:
F28A211FCEA7B19D
Start Procedure done
Next algorithm code download
Device type is: 00
Device Index is: 00
Manufacturer code: 00ec
Device ID: 2250
Extended device ID: 0000
Revision ID: 0121
BB Asic Index is: 0
Device type is: 0
Device Index is: 0
Device contents:
000000000000000000000000000000
Algorithm code downloaded
Next APE algorithm code download
Maximum time for Target flash erasing : 300s and programming 61000s
Using timeout value: 61300s
Target programming failed
Next Target disconnect
Flashbus Tx buffer dump:
6600FF
Flashbus Rx buffer dump:
C102100D010100EC00A1008000150011130101009600000000 0000000000
Error! Phone program failed!
Fail code: H8401b58c
Error code B58C
Flashing failed.
How solve a problem !
Thanks about reply
How do i unlock E63? Do not want to put Ph On Contact retailer hicmet MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-28-2010 21:20
HELP SUPPORT!!! ERROR : $NXP3G is not a valid integer value phanthom2o4o SPT BOX 6 11-29-2009 11:29
pls help: Error : box is not calibrated freddy black DreamBox 1 03-28-2008 13:30
Error : You use not calibrated device ocelular DreamBox 10 04-24-2007 15:04
Www.gsmnl1.com : Cheater - Do Not Buy There - He Will Steal You Safrane The Market Feed Back 2 06-14-2002 19:33
Page generated in 0.25423 seconds with 8 queries
