Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-21-2009, 08:00   #1 (permalink)
JaY'Treze's Avatar
Member: 771856
Sonork: 100.1582636
Thanks Meter: 793
Reference N95 8GB Contact Retailer
N95 8GB Contact Retailer done by ZULEA 2.01 FIX PKey KIller
I need to share this n95 8GB contact retailer provider by 3G Uk,this contact retailer cause by wrong unlocking by damaging PROVIDER KEY & CONFIG KEY.
1.You need to flash the unit in high version RM-320 v31.0.015
2.Run the software by ZULEA 2.01 Fix PkeyKiller CLICK ME TO DOWNLOAD
3.Check device' choose interface ufs or jaf then click phone info after info show wrong provider click REPAIR SL.
Here's the log's
Config Key: 0000000000000000
Provider Key: 0000000000000000
Cause of contact retailer
Searching for JAF box ...
JAF box detected
Box firmware version: 1B1
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-320
Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia
IMEI: *******25837358
SP LOCK status:
    Counters:     0/3, 0/10
    Phone is Unlocked
Read Phone Info OK
DONE LOG'S
Config Key: 8000000000000000
Provider Key: 0010100000000000
JAF box detected
Type: RM-320
SP LOCK status:
    Counters:     0/3, 0/10
    Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
    Counters:     0/3, 0/10
    Phone is Unlocked
Reading PM Field 120 Subfield 0 with length 88 bytes
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving to file: RM-320_352061025837358_PM120_PM308_Unlocked_20-04-2009_125500.bin
Saving to file: RM-320_352061025837358_120_and_308_Unlocked_20-04-2009_125500.pm
PM120 and PM308 backup OK
BB5 FLASH bb5challenge ...
ASIC ID: 000000010000022600010006400C192101021103
HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
CMT Boot Ready
Initial PM 308 sent
Certificates sent
Unlocked PM 308 SL buffer received
Unlocked PM 308 field build OK
After unlock.
Writting PM Field 120 Subfield 0 with length 56 bytes
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Fields 120 and 308 written OK
Waiting for phone to power up ...
Type: RM-320
SP LOCK status:
    Block 1: OPEN    Type 5      Data: 00101F
    Counters:     0/3, 0/10
    Phone is Unlocked
Read Phone Info OK
Successfully done.
Unit already done working properly NO AUTO SHUT OFF..
Old 04-21-2009, 20:57   #2 (permalink)
Member: 211028
Sonork: 100.1587652
Thanks Meter: 23
i test this solution but not work
Old 04-21-2009, 22:14   #3 (permalink)
Member: 211028
Sonork: 100.1587652
Thanks Meter: 23
after flash i make REPAIR SL.
JAF box detected
Type: RM-320
IMEI: 354829027898752
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Reading PM Field 120 Subfield 0 with length 152 bytes
Saving to file: RM-320_354829027898752_PM120_PM308_Unlocked_21-04-2009_220457.bin
Saving to file: RM-320_354829027898752_120_and_308_Unlocked_21-04-2009_220457.pm
CMT Boot Ready
Initial PM 308 sent
Certificates sent
Err no (Jobs): 25030091
Old 04-21-2009, 22:15   #4 (permalink)
Member: 211028
Sonork: 100.1587652
Thanks Meter: 23
i look this resultat:
JAF box detected
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
CMT Boot Ready
Initial PM 308 sent
Certificates sent
Old 04-21-2009, 22:30   #5 (permalink)
Member: 211028
Sonork: 100.1587652
Thanks Meter: 23
my problem is solved good work thanks JaY'Treze
JAF box detected
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Reading PM Field 120 Subfield 0 with length 56 bytes
Saving to file: RM-320_354829027898752_PM120_PM308_Unlocked_21-04-2009_221741.bin
Saving to file: RM-320_354829027898752_120_and_308_Unlocked_21-04-2009_221741.pm
CMT Boot Ready
Initial PM 308 sent
Certificates sent
After unlock.
Reset phone ...
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Successfully done.
Old 04-21-2009, 22:34   #6 (permalink)
mariochines's Avatar
Member: 283371
Thanks Meter: 13
your problem is
if you unlock like this donīt have any problem
just read full pm with sx4 jaff from 0 to 512 and save it,
than u read info with zulea soft, make unlocked pm and write it with sx4 jaff auth software .
some versions will be unlocked , some others no and display contact retailer that u must rewrite
the first backup pm readied by sx4 jaff and the phone will turn working but not unlocked
Old 04-21-2009, 22:50   #7 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
help me bro i tested ( version not supported)
JAF box detected
Type: RM-320
IMEI: 356983017908275
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Saving to file: RM-320_356983017908275_PM120_PM308_Unlocked_21-04-2009_234900.bin
Saving to file: RM-320_356983017908275_120_and_308_Unlocked_21-04-2009_234900.pm
ASIC ID: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000400000100000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000004000001000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000040000010000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000400000100000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000004000001000000000000000000000000 0000000000
HASH:
ROM ID:
CMT Boot Ready
Not supported HASH
Old 04-22-2009, 00:33   #8 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
JAF box detected
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
HASH:
ROM ID:
CMT Boot Ready
Not supported HASH
Problemi col cavo..
Cable Problems m8.
Check connections and use at least 10K resistor on BSI
BR (Ciao)
Alex
Old 04-22-2009, 01:05   #9 (permalink)
Registered User
Member: 42036
Thanks Meter: 6
JAF box detected
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Type: RM-320
SP LOCK status:
Counters: 0/3, 0/10
Phone is Unlocked
CMT Boot Ready
Initial PM 308 sent
Certificates sent
I have the same error information, how did you get it fixed, please give me some more information. thanks.
Old 04-22-2009, 04:36   #10 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
Here's the log's
It can not be fixed without rpl, if phone has damaged SP Area or watchdog is oN phone won't accept authorization (SX4), in this case even you repaired SP Area(FFFFFF can be repair not 00000) phone will work perfect but it will be shut off or restart after 10-30 min.
And in your case your phone is on contact service/provider and it need to be SX4 to write the modified pm which is not possible coz watchdog is oN.
However we must use ASK2RPL to fix this problem.
B.R.,
kashi4gul
The Following User Says Thank You to kashi4gul For This Useful Post:
Old 04-22-2009, 09:38   #11 (permalink)
JaY'Treze's Avatar
Member: 771856
Sonork: 100.1582636
Thanks Meter: 793
B.R.,
kashi4gul
No man i cannot make a thread like this w/out test the phone the unit work properly w/out auto shut off ..i test the unit before i give to *******r i observe 1 to 2 days works properly..
Old 04-23-2009, 18:03   #12 (permalink)
moulnisky's Avatar
Member: 947561
In theory could be possible...
If the 000/000 is caused by a try to unlock it with bb5 prince, only the pm308 is damaged and you get the contact service cause the not syncro between pm120 and 308.. trying to unlock it again or doing repair sl will produce a regeneration of the correct PM308. If the firmware of the mobile is one where the pm308 is not write protected (and so looks like) it will be fine.
The contact service caused by zulea 2.01 is different..
It writes the unlocked PM120 on the mobile then fail to write the 308 (Where it is write protected) so the two field are not syncronized any more and you get 000/000 as well.
To fix it, most of the times, is enough write back the back-up of the pm120 (Not write protected so no needs for sx4 auth) back in the mobile to have it sorted out, unlocked but alive..
Alex
Old 04-25-2009, 03:55   #13 (permalink)
Member: 390217
Thanks Meter: 20
n96 after unlock phone startup faild
konfig key now 00000000
can i repair without rpl
Old 04-25-2009, 04:11   #14 (permalink)
Cheater -Don't Deal with him-
Member: 677681
Sonork: 100.1590886
Thanks Meter: 232
he3 what a joke i did
not see any picture
contact retailer before
operation ....................
need rpl
Old 04-25-2009, 05:38   #15 (permalink)
Member: 176522
Thanks Meter: 17
done without flashing......just write backup LOCKED_PM then unlock again...done it within 30 minutes trying...
The Following User Says Thank You to carlluvjo For This Useful Post:
N95 8gb contact retailer ?? houari Nokia Base Band 5 ( BB-5 ) 16 06-20-2009 06:08
n95 8gb contact retailer pls help 00aa Universalbox 13 05-11-2009 16:25
help n95 8gb contact retailer vikas chadha Universalbox 3 03-18-2009 15:55
Page generated in 0.30529 seconds with 9 queries
