Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-29-2009, 10:22   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Nokia 5310 Contact Service
@All
i've one Nokia 5310 with Contact Service, i erased and flashed it write RPL write PM with SX4 then phone power on oOk with Box connection but after few seconds again goes to CONTACT SERVICE. here is the Selft Test Log.
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Reading Info...
Soft Version: V 08.32 Date: 23-07-08 Type: RM-303 (5310 XPRESS MUSIC) Pack: (c) Nokia
Product code: 0547038
Original IMEI: 353204-03-********
Production serial: KPA797351
HW Version: 2013
DSP Version: ICPR71_08w22
LCD Version: SEIKO
APE ADSP Version:
SIMLock service: SIMLOCK SERVER [01000407031E]
Profile bits: 8000000000000000
Simlock config: 0010100000000000
 Invalid codes entered: 0 / 0
 Block: 1; Lock: 1; State: Open; Data: 00101F
 All locks are open.
Executing self tests...
No signal [0C]  ST_EAR_DATA_LOOP_TEST
Passed [0D]  ST_SIM_CLK_LOOP_TEST
Passed [0F]  ST_SIM_IO_CTRL_LOOP_TEST
Passed [2E]  ST_SLEEP_X_LOOP_TEST
Passed [07]  ST_UEM_CBUS_IF_TEST
Passed [16]  ST_KEYBOARD_STUCK_TEST
Minor [2B]  ST_CAMERA_IF_TEST
Passed [15]  ST_LCD_TEST
Fail [2C]  ST_LPRF_IF_TEST
Fail [02]  ST_LPRF_AUDIO_LINES_TEST
Passed [2A]  ST_CURRENT_CONS_TEST
Passed [45]  ST_RADIO_TEST
Passed [21]  ST_BACKLIGHT_TEST
Minor [5D]  ST_SIM_LOCK_TEST
Passed [47]  ST_SECURITY_TEST
Fail [60]  ST_BT_WAKEUP_TEST
Passed [58]  ST_HOOKINT_TEST
Passed [38]  ST_TAHVOINT_TEST
Passed [65]  ST_SLEEPCLK_FREQ_TEST
Passed [6B]  ST_BTEMP_TEST
Fail [20]  ST_BT_SLEEP_CLK_TEST
Passed [77]  ST_AMB_LIGHT_SENSOR_TEST
Passed [6C]  ST_IIC_TEST
Not executed [56]  ST_EXT_DEVICE_TEST
Not executed [53]  ST_CDSP_RF_BB_IF_TEST
Not executed [50]  ST_CDSP_RF_SUPPLY_TEST
Not executed [51]  ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Not executed [4D]  ST_CDSP_RX_IQ_LOOP_BACK_TEST
Not executed [00]  ST_CDSP_GSM_TX_POWER_TEST
TBB5SelfTestThread 2.7.7.2090 finished at: 2009/05/29 12:17:25
Done.
i'm surprised that it works for few seconds then again it goes to contact services even with bettery sometime it works fine but after few minutes goto contact service.
Take Care
ENJOY
Old 05-29-2009, 12:51   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Unlock it again and do a BT repair.
Alex
Old 09-05-2009, 12:03   #3 (permalink)
pvick's Avatar
Member: 869387
Thanks Meter: 40
How to do the BT repair man? What means those _BT_ failed tests??
Old 09-05-2009, 12:50   #4 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
my problem is solved that was a h/w problem with the phone near power button, my hardware technician fixed the problem.
Take Care
ENJOY
Old 09-05-2009, 13:14   #5 (permalink)
Member: 108365
Sx4 with MT-box ,select PM,tick only Resource 1 and 135.then write PM
PM load here
Tessted
nokia 5310 contact service pls help 00aa Universalbox 19 03-30-2009 21:08
Nokia 5310 contact services... Celhack Universalbox 3 03-20-2009 16:56
Having nokia 5310 contact service kumar_pvj Nokia Base Band 5 ( BB-5 ) 5 12-26-2008 09:41
Page generated in 0.22858 seconds with 9 queries
