01-13-2010, 16:45 | #4 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ((Hassan Mobile)) Age: 37
Member: 908729 Status: Offline Sonork: 100.1589748 Thanks Meter: 152 | Cpu 2292 unlock ok . chip 2293 not support . wait |
The Following User Says Thank You to h_mobiles For This Useful Post: |
01-13-2010, 16:49 | #5 (permalink) |
Member: 908729 Status: Offline Sonork: 100.1589748 Thanks Meter: 152 | see this unlock for mx key 1202 unlock succeesfulyy. Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00244FF8A3BDA66 ASIC type: 11 UEM Imei: 3569(((((((((((((((( Processing file: rh112_003.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00244FF8:2984DA60 Area [01000000-0100FFFF] erased in 1.000 s Area [01010000-013AFFFF] erased in 55.641 s Area [013B0000-013EFFFF] erased in 3.906 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 13.890 s File Processed in 1 min 21.390 s Formating FS: FILE2 ... Processing file: rh1120_nai03.00aa as CNT [DCT4,DCT4 ALGORITHM] size: 132.83 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00244FF8:2984DA60 Area [01380000-013AFFFF] erased in 2.906 s Flash programming ... Programming completed in 0.797 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 17.047 s Processing file: rh112_003.00aa as PPM [DCT4,DCT4 ALGORITHM] size: 1.05 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00244FF8:2984DA60 Area [01240000-0124FFFF] erased in 0.953 s Area [01250000-0137FFFF] erased in 18.187 s Flash programming ... Programming completed in 6.375 s File Processed in 32.375 s Flashing completed in 2 min 47.375 s After Flash Processing ... License is not active, please Update License ! Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35692((((((((((((( Product Code: 0590461 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AA Language Pack: - not available. Imei net: 356************* Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 7.000 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 3.344 s |
01-13-2010, 19:12 | #6 (permalink) | |
No Life Poster Join Date: Nov 2005
Member: 203352 Status: Offline Sonork: 100.1609650 Thanks Meter: 244 | Quote:
this is flashing log not unloking | |
1202 Contact Service .............help | lahoot | Nokia Hardware & Hardware Repair | 40 | 06-04-2011 20:09 |
5130 Contact Service ? help needed | Moiz Khan | Nokia Base Band 5 ( BB-5 ) | 1 | 02-15-2010 09:22 |
3100 Rh-19 contact service help need | abdurrahimsagar | Nokia Hardware & Hardware Repair | 3 | 01-28-2010 12:32 |
1202 contact service help need | abdurrahimsagar | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 01-15-2010 15:18 |
