Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 02-13-2012, 13:04   #1 (permalink)
Member: 479049
Thanks Meter: 41
6300 sl3
please why nokia 6300 should be sl3 security
Old 02-14-2012, 10:48   #2 (permalink)
Member: 457470
Thanks Meter: 159
it cannot be sl3 re check
Old 02-14-2012, 14:09   #3 (permalink)
Member: 479049
Thanks Meter: 41
thanks bro i have fry to check it the same sl3,but i try to flash it now shows contact service with curupt imen
Old 02-14-2012, 14:16   #4 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
sl3 also exist in nokia 6300 .
Old 02-14-2012, 14:27   #5 (permalink)
Member: 457470
Thanks Meter: 159
rewrite backup.
And try unlock with mxkey using rpl unlock
Old 02-15-2012, 09:40   #6 (permalink)
Member: 479049
Thanks Meter: 41
yes sl3 also exist from the phone
Old 02-15-2012, 10:01   #7 (permalink)
Member: 479049
Thanks Meter: 41
my question is why is like that because is two phone the second one is 6500s and this is log
FOR CHECK-
Connect phone on selected interface...
boot - Ok
Read and Check phone data...
BB5 bus checking...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101003000
CMT EM0 ID : 00000295
CMT EM1 ID : 00000B22
CMT PUB ID : 0310010F3AE17C56DE2F924989910697D36A04ED
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 003F0001 , CMT , NOR
CMT Flash ID : 003F0001 < SPANSION => 72NS512P
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0
CMT Algo sent
CMT PAPUB : 2B2A191B54288A818699B64E68916FE1E6A8562D32
Transmission mode : Dual (Ddr, TX2)
Boot Done!
PrReq : NOR , 00
Init Service mode... Wait...
SDD Key status : SDData is Ok
SimLock status : SimLock is Ok
Security status : Security is Ok
PA_SimLock Version :
PA_SL3 phone detected , SP_CODE_LEN : 15
Done!
FOR PHONE INFO-
Reading Phone Info....
Connected phone - Nokia 6500s-1
Software ver : V 59.60 21-11-08 RM-240 (c) Nokia
IMEI : 356854023223597
Ape Ver :
APE Var :
APE ADSP:
DSP Ver : ICPR71_08w30
APE Test:
PPM : V 59.60
21-11-08
RM-240
(c) Nokia
O
CNT : Content: c_uk_ora_uk_v2
V 59.60
21-11-08
RM-240
(c) Nokia
Product SN : KLM850854
Product code : 0574362
Base Prd.code: 0550669
Module code : 0203327
Long Prod.SN : 0
Hardware info=======
HWID : 2002
Retu : 15
Tahvo : 22
Batery: 4627 mV
Camera:
CMT BT: Error
APE BT: Error
APE HW: Error
LCDVer: SHARP
RF ic : 17141715
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key : 8000000000000000
Provider key : 2343300000000000
Provider : Orange;United Kingdom
Counters : Key 1 [3] , Fbus 0 [10]
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
User Code : 12345
MMC pwd : Backup saved
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 02-15-2012, 10:19   #8 (permalink)
bod
Member: 16490
Sonork: 100.1621293
Thanks Meter: 908
Some Models are like that because of the Firmware Version
Examples:
3600 Slide (RM-352) v56.26 - v57.23
5310 XpressMusic (RM-303) v58.58 - v59.42
6300 (RM-217) v57.20
6500 Slide (RM-240) v59.60
6500 Classic (RM-265) v59.45
7610 Slide (RM-354) v57.23
You can check for other Models.
Old 02-15-2012, 10:20   #9 (permalink)
Member: 207590
Thanks Meter: 51
V59.60, on 6500s, 6300 ist SL3
Hp 6300 flash file? hvelect Various 1 04-09-2010 17:07
RM127 6300 flashfile saiful2001 Nokia Base Band 5 ( BB-5 ) 8 02-18-2007 20:09
hp 6300 unlock needed arifdreamworld HTC & PDA WM( With Touchscreen) 1 01-31-2005 17:39
Samsung 600/2100/6300 Unlocking Kanniball VLSI, Conexant, Skyworks and Old Models 2 05-28-2001 12:40
Page generated in 0.20049 seconds with 9 queries
