Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
07-10-2000, 15:49 | #16 (permalink) |
Banned Join Date: Jun 2000 Location: IN Samsung CERTS! Age: 38
Member: 1651 Status: Offline Sonork: 100.1623070 Thanks Meter: 110 | That can be possible that u don't have a connection. I already have written that the Production Date is not important. Some Production Plant's of Ericsson Handy use a new kind of EEPRom other have changed the Connection Pins. If u can't connect your phone with standard ER2000 and Saras 2.2 (cracked) do following. PIN 12 is the right one if Keybord is on the upper side. So close Pin 7 and 8 !! These PIN's are independent to the connection process off phone !! Try to use Saras Workshop 2.2 cracked by SuperDupond or ER2000 modified by SFR. These Programs are therefor to get connection with phone. And u will see it will work ! Programs u found on www.gsmfactory.com/ericsson b.R. GSM-Lupo |
07-10-2000, 18:01 | #17 (permalink) |
Junior Member Join Date: Jul 2000
Member: 1707 Status: Offline Thanks Meter: 0 | Hello GSM-Lupo, I have the same Problem with flashing my T10 (00W21 debitel), everytime I turn it on the display shows "Insert correct Card". I can flash the phone with Saras Workshop 2.2 (er2000 don't work), the Programm seems to work fine; I have flashed In990723.r2a in990917.r3a, in000114.r4a and when ask the Version with ">*<<*<*" the phone displays the flashed version. But all of this aktion is useless, the phone is locked. It seems that my eeprom is corrupted in some way. I got no programm to read ist, opening the eeprom window in Saras Workshop, only shows a white window (theres no dump in it). I only able to read the eeprom when its soldert out, but I have done it to late (after it was totaly locked . Any hints ... Regards lockOver |
07-10-2000, 19:52 | #18 (permalink) | |
Junior Member Join Date: Jun 2000 Location: dynamic
Member: 1511 Status: Offline Thanks Meter: 0 | Quote:
You may use Cage EEPROM up/downloader 0.8 and upload some EEPROM that is working with the version of the phone flash. Then you should use Workshop 2.2 and change the IMEI to desired (original) value. Bye. | |
07-10-2000, 21:22 | #19 (permalink) |
Member: 1707 Status: Offline Thanks Meter: 0 | Hello Firebird, I tried Version 0.80.000 beta of Cage Eeprom up/downloader, but it dosen't work; It can't connect to the phone ("Error! Expected any character" ... but phone is sending something, I can see it with a terminal Programm). How can I find a working Eeprom, these are the eeproms I have: t10_520040519357385.bin t10_520040514250668.bin t10_520040515011515.bin t10_520040515370366.bin t10_520040516453179.bin t10_520040517472913.bin t10_520040518878712.bin t10_520040513803707.bin but when I load them into er2000 the shown production code differs to the one of my phone (I soldered out my eeprom ... If I got the right eeprom Version I can write it with pony prog) Regards lockOver |
07-11-2000, 06:33 | #20 (permalink) |
Member: 1695 Status: Offline Thanks Meter: 0 | Small question, I have tried do programm the t10 00w23 with er2000. After the programm erase the eeprom itīs terminated! So I canīt turne the phone on( nothing in eeprom)! All progs want to start a function, when I press the NO key. But my Phone donīt do anything!!!! I need a programm or a funktion, where I can start the procedure from the Computer, or is there a other way to reanimate my phone without solder the eeprom? thx and cu mrFloyd |
07-11-2000, 07:02 | #21 (permalink) |
Freak Poster Join Date: May 2000 Location: Germany
Member: 1385 Status: Offline Thanks Meter: 1 | Hello I'm use Cage EEPROM up/downloader and phone (T10s) is dead, after that I can't run any program with this phone (ER2000, Saras 1.1/2.2, Cage EEPROM up/downloader,ERICSSON A1018s/Txx flasher made in UKRAINE, etc.) I'm change cable pinout - but nothing. Program eeprom with many bin files from net -same thing - dead ;-). And my friend is send me bin file readed from live T10 (00w23) with ponyprog and I'm upload file with ponyprog............. and phone is LIVE! After that Saras 2.2 working fine with Te125112.bin (voice f. working). Thanks to all who help me!! ;-) [email protected] [This message has been edited by unlockerbh (edited 11 July 2000).] |
need device from Ericsson T10s | kazus | Old Ericsson Phones & Sony Phones | 0 | 09-05-2000 19:43 |
Ericsson T10s 00W25 - problem! | mag.Unlock | Old Ericsson Phones & Sony Phones | 3 | 09-04-2000 21:48 |
ERICSSON T10 00W23 unlock? | MrFloyd | Old Ericsson Phones & Sony Phones | 1 | 07-07-2000 12:56 |
Help me to Find Worked Flash programm For Ericsson T10/T18 phones. | jonwillow | Old Ericsson Phones & Sony Phones | 0 | 03-09-2000 08:00 |
Test New Ericsson T10s - See it. | jonwillow | Old Ericsson Phones & Sony Phones | 2 | 01-22-2000 18:08 |
