insert correct card problem a 1018 s can any body help me????????????? i have flash the phone w cruiser and the other old stuff still not working.....regards. |
Have you try upgrade security from cruiser and then ty to re-flash? |
don't forget to program eeprom! Must b the same version with flash! |
re Quote:
this is eeprom crc error. repair crc with old varanius 0.11 or direct unlock it. (maybe you need to upload working eeprom first,and then correct crc) |
it's impossible 2 repair crc with varanius - IT'S A1018! 2 freakyass , I have only old fw version (b4 tetris) |
@Legas: you are right,varanius can not repair A1018 crc. But it's excellent for upload new eerpom,very fast! For repair crc use ATR 5.0 unlock button,better than ATR 5.3, 'coz it has a little bug for 'new' A1018. Flashing new firmware will not repair it,as I said it's eeprom crc error (equal to 4 locks closed in new SE phones). Upload working eeprom (not need to match to firmware version!) and unlock. Note,that eeprom version does not need to be the same as firmvare version,but sometimes if eeprom does not fit to firmvare,phones LCD will be blank. Do not worry,just try with other eeprom dump. |
I have some prog called eric lcd changer - very helpful. Quote:
u need to rebuild imei then full flash with Ericsson ATR.' |
re Quote:
Check this (flash files - *.sbn files) |
there are few old;) softwares named "er2000" and "special robby" that can make this in few secundes... those are the differencies between generations:p best regards vali |
the thread is " insert correct card problem a 1018 s " not about flashing....:rolleyes: best regards vali |
few old softwares can fix "insert correct card" for old fw;) |
