Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
06-06-2000, 23:36 | #1 (permalink) |
Junior Member Join Date: May 2000
Member: 1398 Status: Offline Thanks Meter: 0 | T10 00114 help? I have the problem with T10 00114..cant remove the insert correct card message. I have external +5 on pin 1, shunt pin 5-6 NOT connected to external.. I'm using saras 2.2 only soft which can connect for me. Can you explain me the whole procedure. Thank you very much.. I can't connect with er2000 ... it says power on the phone (i power) , says tx detected , progres bar, thet it just freeze... atx flasher and other ericsson flasher says when I try to flash wrong response from phone ..... |
06-07-2000, 03:25 | #4 (permalink) |
Freak Poster Join Date: May 2000
Member: 1406 Status: Offline Thanks Meter: 0 | Hi May be I can help you. (I unlocked several of them via Ericsson ATxx 2.2 by Saras or Datex) So you need this soft opcouse. 1. Full charge battery, use external 9-12v power on 7805. 2. You need txwest.rxx 3. Convert this rxx to bin via Ericsson flash converter 4. Run Atxx and enter the passwords (donno it is required or not but better to enter them 5. First connect and UNLOCK it. 6. Remove battery,and insert it again when it say so. 7. Do flash step 1 8. Do flash step 2 (but uncheck USE INI SETTING checkbox before do this step ) 9. Select txwest.bin when it asks to open the flash file. 10.And thats all Note: It seems need to rerun the proggy every flash. As it wouldnt flash on next continouis flashing. You can download all those soft and files from Darek gsm site http://www.zse.edu.pl/~darekgsm/ Good luck. [This message has been edited by GreEn (edited 07 June 2000).] |
06-07-2000, 07:47 | #5 (permalink) |
Member: 1398 Status: Offline Thanks Meter: 0 | It's seems that it's the problem with IMEI.. I can flash succefully (saras beeps and powers on) but the message "Insert correct card stays".... IMEI read by Saras and IMEI *#06# AREN'T the same.... phone says some crazy IMEI when *#06# |
06-08-2000, 02:24 | #6 (permalink) |
Member: 1406 Status: Offline Thanks Meter: 0 | Here again. Here where I am living IMEI is not important. So I dont care ont that. But I have one trick (donno work or not better try it) When using Cages flash converter it will ask to add or remove imei from the list. Add your own remove others. Also on Atx you can change imei after flashing. Set your own also. And see what will happen. Please let me know what happend. |
06-08-2000, 15:36 | #8 (permalink) |
Member: 1398 Status: Offline Thanks Meter: 0 | I think it's the problem with the version. Ericsson T10 00w04 unlocks with no problem but T10 00w07 shows "insert correct card", which I can't remove. Any one unlocked 00w07 T10 with saras 2.2 ?? |
06-22-2000, 19:09 | #9 (permalink) |
No Life Poster Join Date: Dec 1999 Location: Sweden Age: 45
Member: 739 Status: Offline Thanks Meter: 0 | Ihave a problem i can not flash whide step one in datex 2.2 it's say t1x detect after 3sek it's say *no respons from the phone 4* can any one tell me what's the problem flashing whide step2 is no problem but step1 is problem if there is some one ho can help me please please... Best regard GsmHq mail:[email protected] |
06-23-2000, 21:12 | #10 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello Tombach: Try this... I also have some problems with 00W07 and 00W08... but here is MY way to solve it. Give it a try... Use saras 2.2 cracked version of course and go to expert mode. Uncheck "Use INI"... and check 'Ask IMEI'. now press 'All' button. Follow the on screen instructions and when the program does not detect your phone after some steps of power on, remove the battery quickly (even if the program does not tell you to) and put it back and press 'No' for a very short moment. Program will again detect your phone. Dont forget to put your original IMEI when asked ok. Now when all is done, phone will turn on and will say 'Insert Correct Card'. Close Saras proggie and run Ericsson Tools 2kay (ER2000). Remove battery of phone and put back again. Flash the phone again with ER2000. Again, if the program does not detect your phone, remove the battery, put back quickly and press 'No' again. When flashing is done, hopefully your phone will be ok, but IMEI is changed TIPS: Use full charge battery Remove SIM card Press 'No' very very very quickly, if you press too long your phone may be damaged! Here is very strange thing that I noticed, I used same flash file for Saras and ER2000, I just changed the format from rxx to bin. But in Saras, phone is not ok. But when same flash file is used with ER2000, sometimes it will work!!! Hmmmm my guess is maybe some CRC checking problem and Checksum miscalculations... Good luck man! Best Regards, X-Shadow |
T10 00W41 = HELP! | -Jabroni- | Old Ericsson Phones & Sony Phones | 2 | 04-24-2001 19:32 |
t10 unlock help | kick | Old Ericsson Phones & Sony Phones | 4 | 03-23-2001 14:34 |
Dead T10s.. please help ! Thanks | Salute | Old Ericsson Phones & Sony Phones | 1 | 11-02-2000 03:50 |
Death T10s please help me - not beginer | Eerchant | Old Ericsson Phones & Sony Phones | 10 | 10-16-2000 09:21 |
T10 00w33 help! | jimbob | Old Ericsson Phones & Sony Phones | 2 | 09-19-2000 22:42 |
