05-29-2005, 08:45 | #2 (permalink) | |
Freak Poster Join Date: May 2005 Location: Ghana Age: 53
Member: 147362 Status: Offline Thanks Meter: 11 | Quote:
We use SWAP USB Box + hardware secuirty key and plus sumthing else Swap Last edited by S.W.A.P; 05-30-2005 at 14:43. | |
05-29-2005, 13:31 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: allsiemens.com Age: 38
Member: 15925 Status: Offline Thanks Meter: 11 | Lol All it will not help Because you can put com cable with RX to RX and TX connact on Phone and then you can see what is happend Or portmon software if you use Comport or Com emulator. 2. All it is supported by Freia and free SST or cracked. 3. X65 and russian people can use Papuas software it work with TP and ETC. |
05-30-2005, 04:27 | #4 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Inside 8250 UART and 8086 CPU ;-)
Member: 33079 Status: Offline Thanks Meter: 2 | Yeah, true. Serial communication cannot be protected ;-) Not only PortMon, you can just make a nice "spy-cable" to redirect RS232 communication to 2 other PCs (one PC for each direction - just in case the communication is full-duplex) Software for capturing RS232 communications can be done in 5 minutes in DOS. So don't even need PortMon (because SWAP-Team could detect it and kick the process to prevent spying) - hardware solution by "spy-cable" cannot be detected ;-) And LOG-2-MAP algorithm is publicly known for Siemens phones and still the same... This is my way of spying RS232 comms. Using generic dongle is not good idea always - only if implemented properly... Last edited by S.W.A.P; 05-30-2005 at 14:46. |
05-30-2005, 06:28 | #5 (permalink) |
Member: 15925 Status: Offline Thanks Meter: 11 | Do you think they use something other that SST or Martech ? Allways the same ... The best solution for all siemens to crack winswup signature and rsa keys and you can unlock any siemens without any testpoint(only with worked phone) soo... that is nothing news. where is found mastercodes from fullflash\phone ? or found BFB Key in X55\X60 ? P.S. With RS232 better not crack software,to write software manual,because all algorithmys to creat unlock map is free P.S. With 'put com cable with RX to RX and TX connact on Phone and then you can see what is happend' i mean other PC with comport and software to read bytes |
05-30-2005, 14:49 | #6 (permalink) | |
No " RS232" COM port is used!!! | |
05-30-2005, 21:00 | #7 (permalink) | |
Member: 15925 Status: Offline Thanks Meter: 11 | Quote:
and ? Try to connect RS232 cable to other PC,write one software to read bytes. Put RX cable(RS232) to your Box on RX and TX and you will see all what will be happend. Or try to use USB monitor. BR | |
05-31-2005, 12:19 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | i think swap has no attractions for its customers because all free soft of siemens are doing well as swap..even if u r using crack sst you dont need to buy swap |
06-02-2005, 00:07 | #10 (permalink) |
Member: 33079 Status: Offline Thanks Meter: 2 | What is this "SWAP Box". Is it an usual USB-2-RS232 containing FTDI-chip (like found in many uniboxes, Vygis unibox, Infinity unibox)? Or even worse Prolific ;-) If "SWAP Box" actually contains some custom logic (like programmed MCU or FPGA), why is there a need for the dongle? We want to see some screenshots of this software... @karabey: You are reseller for SWAP, did you get any screenshots? Last edited by S.W.A.P; 06-02-2005 at 08:12. |
06-02-2005, 01:14 | #11 (permalink) | |
06-02-2005, 02:37 | #12 (permalink) | |
No Life Poster Join Date: Nov 2003 Age: 43
Member: 45183 Status: Offline Thanks Meter: 474 | Quote:
I am Distributor for Europe but i didnt get any Screenshots of Software also... | |
06-02-2005, 07:15 | #13 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Well everyone wants news...I was wondering to buy it if they include needles or anything as well as I tought it could be interesting if they offer Nec. Please SWAP team any news or info about it...We need some more than two posts. BR |
06-02-2005, 08:21 | #14 (permalink) | |
So if someone clones the box he can use it only with this Hardware Key. | |
06-04-2005, 08:28 | #15 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | @Lpapp,PROTOBUYER Well, if it`s easy to crack/spy/copy/clone, so why don`t you do it? if you don`t wanna do, so don`t speak about it ! If you think swap is a copy of martech etc... SIMPLY DON`T BUY IT! there are a lot of other products which author of them even not used any RX TX rs232 bla bla bla tricks, cuz they are just shells ) why don`t you talk about them?! you think swap is useless? no mind, simply DON`T BUY! If you are a good RX/TX spyman, look around, you can spy swap,pbb3,cruiser bla bla bla and make good money! but unfortunately, YOU CANT at the end , DON`T SPEAK so much, just DO ! |
NEW SECURITY (RESPIN) W200 flash Done !! | mbiborna | SETool2 | 0 | 03-29-2010 13:54 |
Unlock BlackBerry Old & New Security MEP codes - Instant | dmitrik | Main Sales Section | 0 | 03-29-2010 12:36 |
swap manual swap.chm | Mr Twitch | SWAP | 3 | 11-08-2005 19:18 |
NOKIA: 8810's will be swapped for 8850's | MrProdent | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-26-2000 12:22 |
Phone Personality Swap Software ? | John Doe | Old Ericsson Phones & Sony Phones | 0 | 06-02-1999 17:40 |
