11-05-2005, 18:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | how can i unlock th4 756 with polar? i need help, i have an th4 756 locked to GoTone china, and polar, when i put the ot535 cable, the phone power on itself, so i got comunication error in the softwere. how can i unlock the phone, with or without battery?..... the phone must be on, off?... what cable....did i need testpoint..? need help step by step pleese. thanks |
11-05-2005, 19:56 | #3 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | the cable wich comes with my dongle is damaged, from factory ...good begening but with unibox i have fixed it, i can now connect the phone but i can't unlock the unlock bottun doesn't apear, it's still hiden!! what's wrong? Last edited by .:bono:.; 11-06-2005 at 01:09. |
11-06-2005, 12:02 | #5 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
i see that it's version is supported | |
11-06-2005, 13:02 | #7 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | ok i can't read flash i got the error in pic. but after trying to read flash, the unlock buttton apears, but i can't unlock, error in pic. i want to tell u, that i have tryed to unlock the phone by vygis cracked, the prosses in done well and the software said that unlock is done, but the phone is still locked!! strange phone, i make it's pic here with sim. |
11-06-2005, 13:29 | #9 (permalink) | |
and i have unibox, with the switch 5v, have i to swich it on? | |
11-06-2005, 17:41 | #10 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Yes, Alcatel need battery and extra battery in order to could manage with the phones. Pleae try to get another cable in order to see if everything was well done. As we can see main problems with PolarBox are only cables Great work Fistro BR Luskao |
11-06-2005, 18:03 | #11 (permalink) | |
it's begin good with damaged cable in the first use. anyway, could u explain me what is the extra battery, and where it should be connected.... another thing, in the original cable, there are two wiers, one black and the other red, i tested them, the red is -and the black is + stange....where they must be conected. or could u explain how to unlock this phone step by step. thanks | |
11-07-2005, 00:20 | #12 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | The wires must be connected in a 9V battery in order to access the phone but seems that your reseller got some cables damaged. That's not Polar's fault.This is the procedure. 1.Connect your phone with phone battery and 9V battery BOTH attached. 2.Connect the COM cable in any of the free slots of your computer, make sure that you have selected correct COM port in software. 3. Press connect. Software should ask you to power on. Check also that all the pins are making contact well. Press it to be sure about it. 4 When the phone is recognised by Polar Software, press unlock as usual making sure that all the pins are making good contact. Also you can check if the cable wires are correctly connected by opening the little plastic case in order to check it or to solder it if it was not correct. BR Luskao |
11-07-2005, 01:30 | #13 (permalink) | |
i did all what u said, but the software didn't ask me to power on the phone, so i unlocked the phone powered off, unlock done but the phone is still locked again i think that i missed something, plz have u anything to suggest me? Last edited by .:bono:.; 11-07-2005 at 01:51. | |
11-07-2005, 20:43 | #15 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
Hi bono_x100 Please, read a fullflash of similar version of other phone, and send to support. We will prepare a fullrepair flash for this phone. Please, put in contact with us at [email protected] Best Regards | |
urgent can i unlock samsung i600 with polar [ANSWERED] | ramis_bcn | PolarBox 3 | 6 | 12-22-2009 21:37 |
How Can I Unlock Samsung Z230 With Polar Box2 | nasir iqbal | PolarBox 3 | 3 | 12-02-2007 12:36 |
Canīt Unlock Sharp Phones With Polar Box 2 | david69 | PolarBox 3 | 2 | 10-16-2007 02:08 |
how can i unlock T290i phone with what soft ? | cellularman | Sony Ericsson | 4 | 10-12-2005 11:25 |
how can i unlock my T720 with pst | Quatro7pl | Motorola P2k | 0 | 02-13-2004 13:09 |
